586,546 active members*
3,294 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > BOSS Laser > Plz Help! Wavy line issue on new boss laser
Results 1 to 1 of 1
    Mar 2022
    Unhappy Plz Help! Wavy line issue on new boss laser
    Wondering if anyone has some troubleshooting ideas with this issue I am having. I will try and lay out my setup and what I have tried so far. If I am missing anything, please let me know so I can add it.
    Setup:
    Boss Laser HP 5598
    Running lightburn
    Tried cut speeds ranging from 10mm/s to 350mm/s, same result.
    Tried reducing acceleration in X and Y from 2000 to 200mm/s2 and 3000 to 300mm/s2, same result.
    Motion Parameter Settings image attached along with the issue in question.
    Belt tension:
    Both Y axis belts seem extremely tight. X axis belt seems looser compared to Y axis but still decently tight. - Wasn't going to try and tighten unless yall think that may be my problem?
    Attached Thumbnails Attached Thumbnails signal-2022-03-19-152734_002.jpg   signal-2022-03-19-152606.jpg
