587,473 active members*
3,512 visitors online*
Results 1 to 6 of 6
    Nov 2006
    28
    Problem with homing
    Hi, can somebody please help me with my homing problem. When installing home switches I didn't think about that and now the switch is at '0' position. Tried many settings but looks like I'm missing something.
    It is supposed to search the switch from anywhere towards '0', find it and then go in the opposite direction to the Home position which will be at '0' or somewhere else.
    Many Thanks!
    Filip
    Oct 2010
    156
    Re: Problem with homing
    I don't know if this will help, but let me try. I have my limit switches inside my physical limits. And I have my soft limits inside my switch position.
    My Y axis has a physical limit of > 625.00mm. I set max limit to 625.00mm. I have minimum limit set to -1.0 and home offset set to -40.00mm. Home is set to 0.00mm. I also have Home_Ignore_Limits set to YES.
    I realize I loose a little travel distance doing this, but it seems to work.
    HTH
    Paul
    Nov 2006
    28
    Thank you Paul. I understand what is your setup. The thing is that I'm trying to do it with only one switch which is installed close to the '0' position. So I want '0' and min_limit to be set based on the switch and max_limit to be only soft_limit.
    Greetings,
    vph
    Oct 2010
    156
    Hi vph,
    I only have one switch for each axis. I have home location set inside switch so I can manually move axis toward minimum and software will stop a homed axis before hitting a switch. If axis isn't homed accurately, the switch will stop movement before hitting the physical minimum limit. If my axis is not homed properly and I move toward maximum, it will hit physical max. If homed properly, soft max stops the axis.
    May 2015
    686
    Best advice is to read the chapter in the linuxcnc docs called homing configuration.
    To set a home position say 1" from the switch position you need to set something like
    HOME_OFFSET = -1.0
    in your ini file
    Rod Webster
    www.vehiclemods.net.au
    Nov 2006
    28
    Quote Originally Posted by rodw View Post
    HOME_OFFSET = -1.0
    in your ini file
    Thank you! I read it but couldn't understand it well. So I ended up trying all possible sign combination and found "mine" ;-)
  1. Z homing problem
    By Yurtman in forum Omni CNC
    Last Post: 03-10-2022, 10:21 AM
  2. Homing Problem
    By Macwolf in forum PlanetCNC
    Last Post: 02-09-2022, 03:25 AM
  3. 0M homing problem
    By matic in forum MetalWork Discussion
    Last Post: 06-30-2015, 05:37 AM
  4. Homing Problem
    By garryg in forum Mach Mill
    Last Post: 09-21-2014, 06:59 AM
  5. Homing Problem V4.0.1
    By BMaynard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2006, 07:22 AM
