586,584 active members*
2,590 visitors online*
Page 4 of 8 23456
Results 61 to 80 of 159
  1. #61
    Dec 2020
    167
    Re: Working On A New "Timber Frame" Design and Build.
    Putting the first column together with the bolt plates installed and loose tenon joints holding it all together.
    Attached Thumbnails Attached Thumbnails IMG_9271.jpg   IMG_9272.jpg   IMG_9273.jpg
  2. #62
    Dec 2020
    167
    Little by little it is coming together. Test fit of the first gantry side plate, column and beam connect plate are looking good, I put the second column together this evening, so glue is drying on it now.
    Attached Thumbnails Attached Thumbnails IMG_9277.jpg   IMG_9282.jpg   IMG_9283.jpg
  3. #63
    Dec 2020
    167
    Had to through the cut panels for the beam up on the columns just to see how it is going to look.
    Attached Thumbnails Attached Thumbnails C369C030-DFEC-411A-A131-02938BA5F63B.jpg
  4. #64
    15362
    Quote Originally Posted by peteeng View Post
    Hi Loren - Like those big washers what are they from? Peter
    You should be able to find them any good fastener supply should have them, Fender Washers
    Mactec54
  5. #65
    Jul 2018
    6410
    Hi Mactec - In Oz the are called mud guard washers and although large in dia they are thin and can bend when cranked up on timber. I use large square washers used for timber framing they are 3mm thick or 1/8" and they work well. Peter
  6. #66
    15362
    Fender Washers can be any thickness, normally they are standard washer thickness which are the same thickness as what you are using like this snip, square is good though will have a little more surface area
    Mactec54
  7. #67
    Dec 2020
    167
    I made some good progress over the weekend. I finished building the gantry beam, installed the linear rails, and the rack on the beam. Then mounted the beam and and got it level and plumb. Then muscled the Z-axis up and installed it on the beam rails.
    On Friday I ordered motors, cables, a power supply and some electrical drag chain.
    Attached Thumbnails Attached Thumbnails IMG_9304.jpg   IMG_9303.jpg   IMG_9307.jpg   IMG_9306.jpg
  8. #68
    Jul 2018
    6410
    Hi Loren - The monster is coming to life. Peter
  9. #69
    Jul 2018
    6410
    Hi Loren - You used four rails for the gantry any particular reason? Usually only two? Regards Peter
  10. #70
    Dec 2020
    167
    Four rails?? There are two on one the table, one and each side. Then two on the gantry beam front face, one upper and one lower.
  11. #71
    Jul 2018
    6410
    Hi Loren - you have 4 rails under the gantry, usually only one each side? You have two each side? Peter
    edit - opps I see now that photos on its side!! Peter
  12. #72
    Dec 2020
    167
    For some reason, the forum flipped the photo when I uploaded it.
  13. #73
    Dec 2020
    167
    Paint….lots of paint.
    Attached Thumbnails Attached Thumbnails DF006FA9-FE9D-452A-903C-393892D6CA0D.jpg
  14. #74
    Dec 2020
    167
    Paint is complete, even the belly of the beast was painted.
    I ordered a 2.2 KW G-Penny spindle and a Hitachi WJ200-022SF VFD to power the spindle. I need to make a spindle mounting tram plate to fit the spindle. I ahve it designed, just need to program it and get the big vice set back up on the Tortoise to cut it. The one I already made was for an ATC spindle, and just could not justify that cost right now.
    The main power supply landed today. I'm getting the other electrical components ordered as I sort through the rest of the electrical build.
  15. #75
    Dec 2020
    167
    I installed the X &Y axis hard stops today and started working on the spindle mount plate.
  16. #76
    Jul 2018
    6410
    Hi Loren - Those timber thread inserts are really good. When do you think sawdust will happen? Peter
  17. #77
    Dec 2020
    167
    Hi Pete, I’m probably another 4+ weeks out to having it cutting. I have all the electrical, and still have some components to fabricate for the rotary axis.
  18. #78
    Dec 2020
    167
    Cutting the spindle mounting plate on the Tortoise. Slow but steady!
  19. #79
    Dec 2020
    167
    Finished up the new spindle mount plate.
  20. #80
    Dec 2020
    167
    This is a tie plate between the gantry column and the gantry beam. I had a little bit of gap between the tie plate and the beam. The beam is masked off and epoxy buttered the mating side of the tie plate common to the beam to create a perfect fit shim.
Page 4 of 8 23456
  1. Profile Rail Wood Frame Router, 25" x 37" x 6" working area
    By jpvonoy in forum CNC Wood Router Project Log
    Last Post: 03-01-2019, 03:47 AM
  2. First Build-Steel Frame-Cutting Area 2'3"x2'3"
    By Rock380Star in forum CNC Wood Router Project Log
    Last Post: 04-15-2018, 08:10 AM
  3. Replies: 3
    Last Post: 01-21-2017, 11:01 PM
  4. First Router Build, Is The Frame "Beefy Enough"
    By jimbooboo in forum DIY CNC Router Table Machines
    Last Post: 04-06-2008, 06:49 PM
