586,656 active members*
3,455 visitors online*
Results 1 to 8 of 8
    Jan 2014
    37
    MACH4 makes an arc in a corner
    Hello Forum,
    i guess there must be an on/off switch for this in MACH4 but I don't know where.
    This code should generate a rectangle:
    (60.3, 65.3)
    G90
    G91.1
    G00 X37.5 Y42.2
    M3
    G01 X37.5 Y44.7 F1500
    G03 X35.0 Y47.2 I-2.5 J0.0
    G01 X22.8 Y47.2
    G01 X22.8 Y22.8
    G01 X47.2 Y22.8
    G01 X47.2 Y47.2
    G01 X35.0 Y47.2
    G03 X32.5 Y44.7 I0.0 J-2.5
    M5
    G00 X32.5 Y65.3
    M3
    G01 X32.5 Y62.8
    G03 X35.0 Y60.3 I2.5 J0.0
    G01 X60.3 Y60.3
    G01 X60.3 Y9.7
    G01 X9.7 Y9.7
    G01 X9.7 Y60.3
    G01 X35.0 Y60.3
    G03 X37.5 Y62.8 I0.0 J2.5
    M5
    M30
    MACH4 shows the correct preview, but when i start the programm in every one of the four corners the laser travels on an arc that is not in the NC-Code.
    So I have a rectangle with rounded corners.
    Sep 2017
    40
    Re: MACH4 makes an arc in a corner
    Just tried your code in UCCNC and it works perfectly must be some setting in Mach 4 that is either not set or corrupted.
    Dec 2013
    5717
    It would seem that the arcs are in your G code, with a 2.5 radius.
    M3
    G01 X22.8 Y47.2
    G01 X22.8 Y22.8
    G01 X47.2 Y22.8
    G01 X47.2 Y47.2
    G01 X35.0 Y47.2
    M5
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    37
    those 2.5 radius arcs are lead in and lead outs.
    This is how the NC-Code looks in the preview:
    Attachment 477346
    And while machining MACH4 adds these arcs (in Blue):
    Attachment 477348
    Jan 2018
    1516
    Looks like it's doing something to do with "smoothing around corners".
    Could be something selected/checked in cam/post script that doesn't show up in simulation.
    Jan 2014
    37
    There must be a setting in MACH4 or an M / G code that I do not know, that will activade/deactivade this behaviour.
    Nov 2019
    4
    It is most likely Your constant velocity setting, Mach creates round corners to keep speed constant. You can turn off in control and check Exact Stop but your machine my run slow or make a lot of jerking motions.
    Nov 2013
    4444
    Try using Exact Stop mode to see if the behaviour changes, in the Mach/Control/Defaults plugin.
    If Exact Stop improves the corner rounding then you must either continue using Exact Stop OR improve your Constant Velocity settings.
    The most overlooked problem is that you have a machine acceleration which is too low. Most people have the max velocity wound up as high as they can without
    losing steps but then have to limit the machine acceleration....mistake. High acceleration = best toolpath following, and incidentally often the best overall machine
    speed and minimum cycle time.
    Try halving the machine velocity but increase the acceleration until you start losing steps, then back off by 10%.
    Craig
  1. Replies: 3
    Last Post: 02-06-2022, 09:40 PM
  2. SolidCam to Mach4 Lathe PP arc problems
    By Azalin in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-19-2019, 08:34 PM
  3. Mach4 Help Needed: Potentially Paid Mach4 & CNC Consulting
    By rappinadam in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2018, 06:49 PM
  4. LAser cutting machine makes a wave in a corner at the time of cutting
    By angeldp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2017, 03:51 PM
  5. very strange corner problem, mach3 chopping off arc
    By turbocad6 in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2016, 01:34 PM
