586,536 active members*
2,862 visitors online*
    Mar 2022
    CNC capability
    Looking for CNC capability 5x2.5m sheets of plywood, 30mm thick.Has anyone got a profile CNC that could perform the task?
    Apr 2004
    5741
    Re: CNC capability
    You really have sheets of plywood 5 meters long and 2.5 meters wide? Are the shapes you want to cut out of them really big too?
    Andrew Werby
    Website
    Re: CNC capability
    Omni 2675 Cnc Router Engrave Laker'sLogo To Memory Kobe
    https://youtu.be/hCY7fL9tRmU
    2500*5000mm working area is ok , the only trouble that container inside width is 2300mm , so cnc will be seperate into 3 parts ,then you connect them together by screw .
    so most customer choose working area less 2000mm .
    You can contact with me +8618560201508 or [email protected]
    1230
    Re: CNC capability
    Does the enquiry refer to 5 sheets or 5 metres each sheet?There are a few 3 metreX2metre machines that I know of but 5 metres is out of the ordinary.
