586,525 active members*
3,330 visitors online*
IndustryArena Forum > CAM Software > CamWorks > CAMWorks producing gouged parts with 3D toolpath
    Jun 2020
    5
    Hello all,
    I've been using CAMWorks for a couple years now, and while it works well ~95% of the time, occasionally I'll run into something that stops me dead for a while until I can figure it out. This time it's a pattern projection operation cutting unwanted grooves into a flat, sloped face. I can't figure out why it's doing this to me, and it's driving me nuts. Here's some pictures of the issue: https://imgur.com/a/4ilPoPv
    What things might I be able to try? I'm going crazy trying to figure out what I'm doing wrong.
    Thanks!
    Dec 2021
    7
    Re: CAMWorks producing gouged parts with 3D toolpath
    what do you have the machine deviation set to? If it's set to coarse or use global facet deviation is checked and that number is too coarse then, you can get gouging like this
    Jun 2020
    5
    Issue is that CAMWorks is a weird program with some things. Changing the machining direction 5 degrees solved it.
    Jan 2018
    1516
    The grooves are visible in the actual cad image. It's just following the image like it's told to.
    Clean the cad up me thinks.
    Nov 2011
    Quote Originally Posted by Lotaxi View Post
    Hello all,
    Thanks!
    Try increasing the diameter of the tool by 10-15 percent. It can't be a software problem. It has to be a deflection problem. the tool is too weak
