586,512 active members*
3,496 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Need Help. Z axis getting Deeper
    Hi..!
    i have a problem in making a v carve tool path it start perfectly but suddenly my z axis getting deeper through the material.
    operating software: Mach3
    Designing software : Aspire V10.5 And ArtCAM 2018
    Nov 2013
    4422
    Re: Need Help. Z axis getting Deeper
    the two most likely problems are:
    1) The tool is pulling out of its collet and therefore protruding more as time progresses
    2) The Z axis is losing or gaining steps. Electrical noise interference is a possibility as is the stepper being marginally overloaded at the speed of operation.
    Craig
  1. Z axis suddenly goes deeper while machining
    By zapperone in forum Chinese Machines
    Last Post: 06-25-2021, 05:28 AM
  2. Z Axis slipping deeper
    By vangalvin in forum Linear and Rotary Motion
    Last Post: 12-13-2018, 12:08 AM
  3. Z axis cutting deeper than expected
    By bitsa in forum Chinese Machines
    Last Post: 11-08-2015, 08:40 AM
