586,545 active members*
3,215 visitors online*
IndustryArena Forum > Material Technology > Plastic injection > Plastic injector barrel material?
Results 1 to 8 of 8
    Jan 2015
    23
    Hello everyone, I'm planning on building a ram style plastic injection molding machine and wanted to know what materials people had good results with for the injector barrel and ram?
    I don't plan on using any plastics with chlorine so I'm not sure I really need it to be stainless steel.
    I've seen people make them out of aluminum which sounds like it will just gall quickly. I've also seen people use DOM tube.
    I have a few pieces of 1144 that I could use. I'm planning to use it mostly for PETG. Any advice on this is absolutely appreciated!
    15362
    Re: Plastic injector barrel material?
    Quote Originally Posted by laminated View Post
    1144 would be ok the piston will have to be a similar material because of expansion so need to be close to the same, the 1144 is free machining so won't be much better if any better than Aluminum, the 1144 will hold the heat better I use a tool steel H13 for injector barrels
    Mactec54
    Jan 2015
    23
    Thank you for your reply. H13 sounds like a damn good material to make one from.
    I realized that making it from 1144 is essentially a disposable barrel.
    I thought about useing something like 1045, but thought that 1144 would be more stable ones heated.
    15362
    Yes use what you have you can always make it better if you have too, 1045 is not so good to machine but you could bore and have it honed, then make the piston to suit
    Mactec54
    Jan 2015
    23
    Unfortunately I don't think my small lathe (pm1228) is up to turning h13. Not sure if it's always prehard. I was looking into 304. But I see it has a much higher thermal expansion.
    I would assume it would be less likely to crack from thermal stress similar to cook where.
    I see 304 is also available for a lot on injection components. So not sure how bad of an issue the extension is in real practice.
    For a screw I could see there being issues, but for a ram injector system I think as long as there's good clearance it will work fine.
    15362
    H13 I would say is easier to turn than 304
    303 is free machining and would work just as well as 304 the only real different is that 304 is ok for welding 303 is not so good
    Mactec54
    Jan 2015
    23
    That's pretty surprising. Not really more expensive than stainless for the small size I need. Can it be drilled with cobalt hss? Also is it difficult to tap?
    15362
    Yes, quality regular HSS drills are ok, it taps ok with again quality taps, normal cutting fluids are fine
    Mactec54
  1. outdoor plastic material help!
    By jdhutch82 in forum Composites, Exotic Metals etc
    Last Post: 06-09-2016, 01:03 AM
  2. removing static from a plastic barrel????
    By FUBAR62172 in forum Glass, Plastic and Stone
    Last Post: 02-02-2015, 11:31 PM
  3. Where to buy plastic material
    By bonmotwang in forum DIY CNC Router Table Machines
    Last Post: 07-06-2011, 12:18 AM
  4. Plastic Material
    By rwskinner in forum Engraving Machines
    Last Post: 01-05-2011, 04:15 AM
  5. Plastic as the mold material
    By gcn2339 in forum Vacuum forming, Thermoforming etc
    Last Post: 07-30-2007, 09:31 PM
