586,523 active members*
3,379 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
Results 1 to 9 of 9
    Feb 2022
    Post EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    Hello everyone, I am new to this forum and need to see if I can get some help. I was able to download the driver so my Ezcad2 is not in Demo mode. However, when trying to do just a simple shape to test out laser the laser will "red" button will work fine and outline the square but the "mark" will not work. There is a red light that say not ready on the bottom. When I try to press it to see if it will give me information on error issue but it does nothing. Has anyone encountered this and if so any suggestions? I appreciate any help, thank you.
    Mar 2022
    Re: EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    I too have this same problem, anyone have a solution?
    Mar 2022
    <p>
    Maybe you could try the <a href="https://www.laserchina.com/download/ezcad/" target="_blank">latest EZCAD2 software </a>at the official site.
    </p>
    Mar 2022
    I also have this problem, someone please help. I just spent way too much money on this damn laser for it to not work lol
    Mar 2022
    OK, so I figured it out, go into System Parameters/Param, click Ports, change 'Door IO - Input Port' to NULL. Button should now show READY and will work
    Apr 2022
    Quote Originally Posted by 1kxl View Post
    Is this thread still active?
    I followed the answer here and my door IO and input port are not the same as this any advice.
    My buttons are output IO Mask Output IO Mask
    Apr 2022
    My buttons are input IO Mask Output IO Mask I changed them to null.
    Is null mean zero is checked or is it all are unchecked. Thanks in advance
    Apr 2022
    Mar 2024
    4
    Smile Re: EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    I got the same issue.After changing the IO setting, the problem is still there.
  1. Raycus 30w Laser Software EZCad2.0 Calibration
    By LaserCutter2019 in forum Laser Control Software
    Last Post: 09-24-2020, 06:56 AM
  2. 1 kW Fiber laser machine "without cover"
    By cevdet in forum Fiber Laser Cutting Topics
    Last Post: 02-11-2019, 11:01 AM
  3. Replies: 0
    Last Post: 12-15-2015, 08:01 PM
