586,807 active members*
8,395 visitors online*
    Jan 2006
    55
    Question about ballnuts
    I am building a set of preloaded ball nuts and I was wondering if they need to be facing the same direction. In other words can I have the threaded ends facing each other and threaded into the same block. Or do I have to thread one into the other. Can they go like this -H==H- or does it have to go like this -H=H=- ... The H is the body of the nut where the balls are held,the = is the threaded part and the - is the screw. I hope someone can make sense of this because it would be alot easier if I could thread them into the same block and preload them by threading them apart. Also any advice on getting them started on the screw without losing the balls would be helpful. Thanks
    Jul 2006
    155
    I am going to be mounting my ballscrews in the configuration of the threaded ends facing each other and can see no reason why this would nt be ok. As for getting them on the screw, there might be a cardbord tube inside the nusts right now. Just but that end up against the threads and screw the nut onto the screw.
    "you don't even need cnc if your handy with a torch"
    Jan 2006
    55
    Thanks, that was what I was hoping to hear. That way the table travel will be the same in both directions.The nut holder block is going where the acme nut was mounted. Another side question,can I remove the ball nuts from the screw in the same manner? I still have the cardboard tubes. These ball nuts scare me. I have this vision of little balls rolling away from me and under the lathe or down in a floor drain!
    Oct 2005
    612
    Yes you can carefully remove the ballnut the same way. Take it from somebody that had them scatter across the workshop to do this over a tray with a towel to catch them and stop the bounce factor.
    cheers,
    Rod
    Perth, Western Australia
    Jul 2006
    155
    haha very good advice, the last thing you want is to have to crawl around on your hands and knees trying to find all the balls. if they do fall out though and you catch them all in a tray it is not hard to reload them.
    chris.
  1. Dual ballnuts for the X3, limiting travel?
    By phantomcow2 in forum Benchtop Machines
    Last Post: 07-25-2006, 12:12 AM
  2. Pre-loaded ballnuts now an option at cncfusion.com
    By wisp in forum News Announcements
    Last Post: 07-22-2006, 04:58 AM
  3. Joining 2 Nook Ballnuts - any ideas?
    By Rodm1954 in forum Linear and Rotary Motion
    Last Post: 06-16-2006, 01:16 AM
  4. Ballnuts: Do you really need all the balls?
    By geohot in forum Linear and Rotary Motion
    Last Post: 12-27-2005, 07:34 AM
  5. Anyone selling low cost wipers for ballnuts?
    By sendkeys in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2004, 01:43 AM
