What version of MCam? In X you have to select a post that supports the Rotary function. In V9 you can program Rotary, but the output will not be right if the post does not support it.
There are about 5 different ways to do rotary on Mastercam. All require that the part be on the center line of the axis.
Have you ever done rotary with your post before?
What kind of machine do you have?
If you have V9 you may want to consider this...
http://www.tipsformanufacturing.com/...y_contour.html
This CD includes posts for Vertical and Horizontal machining. It also has information for modifying the posts.
If you have MCam X you may want to consider this...
http://www.tipsformanufacturing.com/...ontouring.html
This one includes a Horizontal post for rotary.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
