I have a 2008 TL14 lathe and the spindle bearings went out. I have replaced them but something isn't right. I have attached a drawing of the assembly on page 23. It doesn't show the directions that the bearings go in to set the load. There are 3 bearing, 2 right at the spindle and one behind the spacer. I feel like they should be under load when taking a cut on the lathe but I could use some help with this. I spoke with Milltronics and they said they should all be facing the center.
