586,545 active members*
3,125 visitors online*
    Nov 2011
    21
    How to make thread with RNR motion board in mach3?
    Hello guys.
    I use it about 3 months but I can't find solution how to get value from proximity sensor in SpindleS true
    It's not a problem to switch on in config-port and pins-Input Signals-index-port 3 pin 1 (any 1-4) and index LED in diagnostics reads signal from sensor but no True PRM value.
    Does someone found way to make thread with RNR motion board?
    Attachment 474954
    Nov 2013
    4430
    Re: How to make thread with RNR motion board in mach3?
    the only thing to recommend an RnR board it that its cheap.....and works sometimes/mostly.
    If you want a better result buy a US or European made motion controller.
    Craig
  1. RNR Mach3 Motion Control Card - MPG connection
    By CrazyJane in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2023, 08:33 PM
  2. Replies: 0
    Last Post: 04-08-2020, 03:52 PM
  3. rnr motion breakoutboard
    By manumv in forum Controller Cards
    Last Post: 02-02-2019, 12:37 AM
  4. Mach3 USB Rnr motion control mpg connection
    By CrazyJane in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 01:21 PM
  5. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
