586,584 active members*
2,880 visitors online*
    Mar 2008
    375
    machining threads off
    let me see if I can explain this, so I have this nut (7/8-9 unc), I would like to set it on a lathe about 10 degrees slanted on the backside, then I will machine the I.D of the thread to a certain I.D dimention. does anyone have any sudjestion or ideas on how to place the nut at an angle? or maybe make a ficture.
    Oct 2010
    21
    Quote Originally Posted by cob View Post
    Mount nut on your tool post. Rotate compound to appropriate angle. Put cutting tool in chuck-mill cutter/drill bit/ boring head. Simplest way to mount nut might be a socket with steel bar welded to it.
    Jun 2012
    182
    Re: machining threads off
    Is the cut a taper parallel to the axis of the nut or is it instead a cylinder at an angle to the axis of the nut?
  1. Diference between (American Petroleum Institute) API threads and BEGER API threads?
    By Marecki_l in forum Mechanical Calculations/Engineering Design
    Last Post: 12-15-2018, 04:46 PM
  2. Replies: 5
    Last Post: 10-31-2012, 02:44 AM
  3. Machining internal acme threads?
    By LazyMan in forum Tormach Personal CNC Mill
    Last Post: 08-13-2011, 01:47 AM
  4. machining threads using 4th axis
    By ncmrfixit in forum G-Code Programing
    Last Post: 12-14-2007, 04:08 AM
