586,565 active members*
3,785 visitors online*
    Mar 2016
    13
    atc spindle setup
    hi everyone.
    i have a 10*5 cnc router with a 4.5kw spindle , non atc.
    i have purchased a hqd 6,5 kw atc spindle and vfd, i am running uccnc with an uc300eth-5lpt controller and a ucbb bob which i upgraded to from a chinese controller and mach3 , apart from the spindle and vfd what other items are needed for the air side of things ,i have a 300 litre compressor also what solenoids are needed ,anyone have any step by step guides of there own setup to atc or know of any good videos available so i can get my head around it.im not using the router at the minute due to other commtments so i have loads of time to get it sorted.
    thanks voyager1972.
    Attached Thumbnails Attached Thumbnails atc spindle.jpg   fuling vfd.jpg   fuling vfd2.jpg
    Mar 2016
    13
    Re: atc spindle setup
    after 2 years of sitting in a box i finally mounted the 6kw hqd atc spindle which i have connected to the vfd and is running smooth , at present i plan to use the manual toolchange button until i get my head around the auto toolchange and macro side of things.. i am using the uc300eth-5lpt with the ucbb with uccnc , i understand how to get the solenoid working with the button , my question is does this have to be connected through the breakout board ? and is there safety measures i need to put in place in case of a tool ejection when the spindle is in use , any advice would be much appreciated. thanks
  1. 3-axis machine RC2130DH-ATC with double ATC spindle for UK customer
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 06-18-2019, 08:09 AM
  2. ATC and power draw bar setup
    By unlock in forum Tormach Personal CNC Mill
    Last Post: 05-15-2012, 09:49 AM
  3. ATC setup help
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 07-14-2011, 11:12 PM
  4. prolight 2000 atc setup
    By Toyhacker in forum Benchtop Machines
    Last Post: 10-28-2007, 12:01 AM
