586,655 active members*
2,985 visitors online*
    Sep 2010
    54
    SHUOGOU CNC Engraving Machine Control Panel
    I got a Chinese laser engraving machine from a friend. Since he hasn't had it in use for a long time, he can't find the software. Next to the laser there are also stainless steel plates with the address of the website with the software (http://cj.hjk.hk), but the website is unreachable. The software is supposed to be called AC master software. There is also a USB converter with a chip, PL-2303TA, which is connected to SHUOGOU CNC Engraving Machine Control Panel. (I can't find any data from the control panel anywhere). When I connect it to the computer via USB, my computer recognizes the Prolific USB-serial comm port (com8). I tried the program 3dpBurnerSender but it does not connect, Ben box does not, laser crest. There are two controllers for stepper motors with the 4998ET chip on the board. When I connect it to the 12v power supply, the fan on the laser rotates and the motors do not hold anything. If I install the drivers for the PL-2303TA chip, the only change is that the laser burns. Can anyone advise me how to revive an engraving machine with existing electronics? I also have an arduino UNO Chinese clone at my disposal. Is it possible to connect SHUOGOU CNC Engraving Machine Control Panel and arduino UNO?
    Sep 2010
    54
    Re: SHUOGOU CNC Engraving Machine Control Panel
    I am adding more pictures:
    Apr 2004
    475
    Gerbl?
    It's an open source motion control system, probably what was used with that. I'm not 100% what hardware you could install it in, but presumably one of the bits you have!
    Its the top choice for hardware that looks like that.
    But, I can't help more, never used it myself.
    Sent from my Nokia 3.4 using Tapatalk
    Sep 2010
    54
    I removed the stepper motor controller. Below the controller is a 15w404as chip. I am interested in which softwear is designed to control stepper motors.
    Sep 2010
    54
    Maybe someone else is right. On another forum, someone pasted a link to a blog where a laser like mine is described and a link to the software.
    LINK
    P.S. I forgot to write that I managed to start the stepper motors.
  1. Control Panel running, Machine is not..HELP
    By Cattle in forum DNC Problems and Solutions
    Last Post: 04-04-2016, 10:20 PM
  2. Control Panel running, Machine is not..HELP
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-04-2016, 09:09 PM
  3. Engraving my Control Panel
    By kolias in forum Mastercam
    Last Post: 10-20-2012, 01:28 PM
  4. Engraving Machine to Engrave Slim Box Light Guide Panel
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2011, 07:22 AM
  5. DIY CNC Milling Machine Control Panel for EMC2
    By gschoep in forum LinuxCNC (formerly EMC2)
    Last Post: 02-23-2011, 05:10 AM
