586,655 active members*
2,447 visitors online*
    Apr 2004
    475
    New build: openbuild / Chinese frakenlaser
    This is just in the planning stages in that the parts (hopefully all of them!) Are ordered.
    I have a 1200*900 Chinese laser from about 8-9 years ago but it's never been great for accuracy. I have modified the lens assembly to be easier to adjust to the beam rather than needed to adjust the beam, but I covet a better system like a Kern laser had, or even the Chinese 4*8 machines but don't want that large.
    So, I'm going to build one myself. I'll get a bit more cutting area in the process too. The plan is to use a sort of beefed up Acro system from openbuild parts and run mount the laser on the gantry. That should allow the alignment of the Y to basically be permanently set and less beam travel overall and thus less power loss from one corner to the other.
    This is primarily for cutting although I hope engraving is possible, no reason it shouldn't be. I'll be taking the openbuilds belt drive and modifying it to run the belt flipped over a little like the belt and pinion style, for the gantry. The Y will be dual drive with actual belt and pinion kit from openbuild stuff.
    The main thing I am losing is the up and down of the table but I could always make new gantry sides if I need to move the assembly higher.
    I hope it will be better than the Chinese machine but it's unlikely to be worse. I'm not a 3D cad guy so I'll just be posting some photos along the way.
    Old machine and a CNC will make parts for the build until the laser tube itself is ready to be transplanted.
    Greg
    Sent from my Nokia 3.4 using Tapatalk
    Apr 2004
    475
    Re: New build: openbuild / Chinese frakenlaser
    So, some of the parts have been coming in. Motors, drivers, enough to remind me I needed encoder cables and didn't buy any so I did that.
    I did want to test a easy way to slave two drives together.
    On a past CNC retrofit, I did the standard y and a slaved in software....had some issues with the BOB, but basically it worked in the end.
    Then I saw some guys running 2 motors from 1 driver.....in reverse. That would not work on a closed loop driver but neat.
    However, I just need to run two motors opposite each other as 1 axis as I'm using a DSP controller for this, a ruida. I wanted to see if daisy chaining the pulse signal and daisy chaining the dir signal (to dir + on one driver and dir - on another) would work.
    It does.
    Mechanical parts coming next week so maybe getting serious in a few weeks.
  1. Replies: 15
    Last Post: 05-11-2019, 04:33 PM
  2. Replies: 13
    Last Post: 06-11-2017, 03:33 AM
  3. www.inventables.com X-Carve Vs OpenBuild Routy?
    By crazynight in forum Want To Buy...Need help!
    Last Post: 02-28-2016, 06:48 PM
  4. opinions on openbuild cartesian style cnc router?
    By stevenj in forum Australia, New Zealand Club House
    Last Post: 01-19-2016, 03:22 AM
  5. Openbuild.com
    By Marti in forum Open Source CNC Machine Designs
    Last Post: 06-15-2013, 06:16 AM
