586,388 active members*
3,328 visitors online*
    Aug 2007
    10
    Fanuc new 0I problem
    Hi, it's the first time for me in a forum. But maybe you can help me. I need the acces to optionel parameter on a new Fanuc 0I , but i'm unable to see 9900 - and up. i need to install a 4th axis in the machine.I know i need to change 9900 from 3 to 4 but i dont see these parameter anymore.
    How can i see these parameter ?
    Best regards
    Dec 2007
    4
    Quote Originally Posted by sylvain View Post
    Best regards
    Helo ,I think it is in the system parameters ,you pres the buton system not offset there are also parameters to set ,it is the buton under the offset buton .
    L.P Boštjan
    Dec 2007
    4
    Parameters
    take a look in the system parameter is the buton under the offset buton ,there are also parameters look for a buton "system"
    Regards
    Boštjan
  1. Fanuc Oi-TA LCD problem
    By rai in forum Fanuc
    Last Post: 01-31-2012, 01:00 PM
  2. FANUC-OM ATC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-27-2007, 04:18 PM
  3. Fanuc OT problem
    By Skybrake in forum Fanuc
    Last Post: 02-09-2007, 07:04 AM
  4. Fanuc 6M Problem
    By Mimas in forum Fanuc
    Last Post: 12-17-2006, 01:03 AM
  5. Fanuc 6mb G54 problem...
    By kangarabbit in forum Fanuc
    Last Post: 05-08-2006, 08:35 PM
