586,655 active members*
2,157 visitors online*
Results 1 to 8 of 8
    Apr 2003
    95
    Taig CNC Mill Leadscrew nut?
    I have the Taig CNC Mill 1/2"-20 Lead screw version and was wondering if anyone knew what bronze the lead screw nuts where made out of? I know I can order them from Taig but just wondering in case one day I need to make my own.
    Thank you,
    Eric
    Apr 2004
    5742
    Re: Taig CNC Mill Leadscrew nut?
    You could ask Taig, I suppose, but if you're worried about it, why not just order some spare nuts?
    Andrew Werby
    Website
    Apr 2003
    95
    That's what I will probably do just order a couple of sets to have in case I need them someday!
    Nov 2013
    4442
    the traditional material for worm gears and nuts is Nickel Tin Bronze.
    You could use any number of bronze types and still have a great result, any of the Aluminum Bronzes (Aluminum-Nickel, Aluminum-Silicon) would work well
    as would Phosphor bronze or even Manganese or plain Tin Bronze.
    Craig
    Apr 2003
    95
    Thanks Craig, I was thinking about Aluminum Bronze but did not know if it would make a difference or not.
    Nov 2013
    4442
    I suspect the nut is fairly lightly loaded and hence are not that critical.
    Astronomers have long had need for extremely accurate and lash free large diameter worm wheels to drive the telescope for photography.
    There has over the years been extensive research over the best materials. NickelTinBronze is the clear winner for the worm wheel and hardened 400 series stainless
    for the worm. The explanation given is that the surface of the gear tooth workhardens as a result of microscopic plastic deformation, and the workhardened surface thereby
    resists further wear.
    Sound like a useful property for a leadscrew nut.
    Craig
    Jul 2007
    1602
    Note that Taig laps the screws and nuts together so you might be better off to replace the two at the same time:
    Aug 2006
    673
    Just FYI,
    I have a full set of screws and nuts left over from my ballscrew conversion if anyone wants/needs them.
  1. Want to buy Taig Z-axis leadscrew nut
    By jaru-eri in forum Want To Buy...Need help!
    Last Post: 09-12-2018, 05:40 PM
  2. Brigeport Knee Mill: leadscrew split nut adjustment issue
    By Thomasio in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2012, 03:27 AM
  3. Leadscrew nut materials
    By ted34 in forum DIY CNC Router Table Machines
    Last Post: 06-17-2009, 10:04 PM
  4. Protecting Taig mill Z-leadscrew
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 05-23-2009, 03:36 PM
  5. x-axis leadscrew nut
    By mjarus in forum Benchtop Machines
    Last Post: 02-19-2006, 07:09 AM
