586,388 active members*
3,346 visitors online*
    Another JGRO Build Completed
    First of all, thanks to everyone for the encouragement. Though it was general community sentiment, the "stick to it" attitude that everyone voices here is really helpful.
    So, after 3 years (and a couple of months), I have finally completed my CNC. I had it writing with a marker last year, but I broke it down to paint before I did all of the wiring. This is a JGRO build straight from the plan. The only modification was the metal plate for the Y-bearing. I used a HobbyCNC motor /controller kit.
    Last night, I ran the first, full up test with the rotary tool powered up and cutting a piece of MDF.
    Here is a close up of the cuts. I took some 180 grit sandpaper over the MDF after the cut to defuzz it.
    ~Dantourin
    Nov 2006
    296
    Nice work dan, hope you get great use out of it, i use mine to do jigs or complex shapes that would otherwise be difficult or impossible to do manually.
    :cheers:
    Sep 2007
    72
    Quote Originally Posted by Dantourin View Post
    ~Dantourin
    ... three years ... talk about 'stick-to-it-edness' ... WoW!!!
    Congrats ...
    May 2005
    362
    That looks great. It looks like you added some length to the original jgro plans.
  1. My JGRO build
    By Sieg in forum Commercial CNC Wood Routers
    Last Post: 10-31-2007, 02:36 PM
  2. My turn at a Jgro build
    By silentreaper in forum Commercial CNC Wood Routers
    Last Post: 06-17-2007, 06:14 AM
  3. JGRo Build by Thinwater
    By Thinwater in forum Commercial CNC Wood Routers
    Last Post: 05-31-2007, 06:30 PM
  4. going to build the jgro
    By clammy23 in forum DIY CNC Router Table Machines
    Last Post: 01-04-2007, 12:44 PM
  5. Yet another jgro build
    By bnoble in forum Commercial CNC Wood Routers
    Last Post: 11-17-2005, 04:51 AM
