Hello everyone,
I want to see if I can make a metalworking manual/cnc lathe. For many years I have wanted a metalworking lathe, but the cost of a quality machine has stopped me every time. I have looked at all the cheap imports that I can afford, and I cannot bring myself to buy one. I want a beautiful precision instrument that is within my abilities to maintain and adapt to my needs as they develop. And I feel the skill and abilities I gain in building my own machines will be worth it.
This website and the projects of various members have greatly inspired me. So, here is where I am so far in my past attempts and in my current thinking on this project.
I have read the Dave Gingery series, and I began my version of his lathe project in fits and starts. I made the lathe bed and ways using a square 2 x 2 steel tube filled with cement that had a 1/4" plate screwed and jb welded to it. I learned how to cast aluminum and made a headstock and feet for the bed. The project stopped when I could not get the headstock moving on the ways smoothly.
Next, I got a 52" Atlas lathe bed on ebay for 20 bucks. The shipping cost more than the bed. This I sand blasted and repainted and then I had the ways reground. The company that ground the ways did not have the ability to grind the underside of the ways, so I began studying scraping. I purchased "Machine Tool Reconditioning" by Connelly, I got a 24 x 18 surface plate and I made my own carbide tipped scrapers.
I was going to then piece together the lathe with parts from other Atlases, but while trying Atlas machines, I realized they did not have the weight and tolerances I was looking for. They were all really worn out.
So, I started looking at old SB 9 and 10 inchers again recently, but the decent looking ones are out of my price range and I do not trust buying one without the thought that I would have it reground and reconditioned. This is an expensive proposition.
So I figure, if I am going to go to all the trouble of rebuilding old machines or rebuilding new, low quality imports, why not start from scratch. In the process, I can also make my lathe more modular, so that upgrading any component is not very hard. DIY makes sense also, because in my various projects I do not need thread cutting ability until I have cnc working. So, I will be happy without all of the split nuts and power feeds and quick change gears. Turning two cairrage handles if fine until I have the steppers hooked up.
Today, I have gotten a lot of ideas studying the various threads on this site and I would like to run them buy anyone who is interested in helping me.
1. I was thinking I could still use the Atlas 52" lathe bed I have. The tops of the ways are ground flat (I do not know how flat, however). Being old, I assume all of the twist has settled out of the casting. I could buy Thompson-type guide rails and attach them to the ways by drilling and tapping holes in the ways. The carraige and tailstock would attach to plates that attach to the Thompson bearings.
2. I have noticed that a lot of builders are starting with the mini-mill and mini-lathe headstocks that Little Machine Shop sells. I like that idea. I am wondering if the mini-mill and the mini-lathe headstocks have the same dimensions for the bearings, because I would like the get the mini-mill headstock and the base casting it attaches to. These two castings I could then bolt to a plate that bolts to the Atlas bed where the original headstock is screwed down. The v groove that is ground in the mini-lathe headstock in also not necessary. Could I get the mini-mill and swap in the mini-lathe spindle? Does anybody know?
3. I am thinking that I could push the mini-lathe/mill headstock, spindle, and bearings to handle a 9 or 10 inch swing as long as I do not take huge cuts. The lathe bed is designed for the 12" Atlas, I think. Any thoughts on this?
4. I could clamp the tailstock along the ways by pushing a gib tight against the outside surface of the original Atlas bed ways. A type of apron could hang down and one or two set screws could be tightened by hand. I don't think this would torque the Thompson guides and bearings too much.
5. I could power the spindle with a timing belt and pulley. I will have to learn which one to get. I am not sure what motor I will use to power it. Any suggestions would be great. It looks like a lot of people are finding tread mill motors and speed controllers.
As, I get further along I will show some drawings, I am also learning to use Rhino 3D.
