586,645 active members*
2,702 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4th axis master cam tool path problem
    Sep 2017
    5
    Question 4th axis master cam tool path problem
    I want to program a cam profile with side milling in master cam on rotary axis while my 4th axis in horizontal position i need help to figure out the post processor and the tool path strategy which should i use rotary tool path either swarf milling thanks full for urgent help
    Apr 2003
    3578
    Re: 4th axis master cam tool path problem
    I suggest you get with your Reseller as there will be a little in-depth work on the post and multiaxis.
    Cadcam
  1. Mastercam Rotary tool path A axis problem
    By Fr0ssT in forum Mastercam
    Last Post: 06-16-2015, 07:45 AM
  2. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  3. 4th axis tool path depth cuts?
    By clivefx in forum Mastercam
    Last Post: 07-20-2011, 09:36 PM
  4. Master Cam Problem Try Not To Laugh
    By Techbuilder in forum Mastercam
    Last Post: 04-04-2011, 01:45 PM
  5. 4-Axis CAM and Tool Path Problem
    By skibbey in forum Uncategorised CAM Discussion
    Last Post: 03-13-2007, 04:05 PM
