586,692 active members*
3,083 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Will not single block when running simulation.
    Jul 2008
    38
    Need help with why it will not let me single block my tool path when I run the simulation. It is just a profile cut. PartMaster Milling & Turning V14.6.2017.3
    I am not using the 3d simulation just the normal run in the lathe module.
    Thanks, machineitright
    Feb 2007
    414
    Re: Will not single block when running simulation.
    Hello,
    I'll look into it.
    Andre
    Jul 2008
    38
    Thanks Andre,
    Do you need my file?
    - - - Updated - - -
    Thanks Andre,
    Feb 2007
    414
    Hello,
    sorry for the delay in getting back to you, I overlooked this.
    Single step will just show a single operation not the whole program, so this is working as expected.
    To see the individual moves you need to use Pause mode, then hit Run and then from the right hand status panel you will see a flashing red button, click this to see each move.
    Click Stop to reset back to normal run mode.
    ATb
    Andre
    Feb 2007
    414
    Oops !
    One thing I forgot to mention is the for Pause to work – the tool view must be set to Animate or Envelope
  1. stuck in single block
    By Tandem1 in forum Fanuc
    Last Post: 04-03-2020, 10:50 AM
  2. Fagor CNC Running single block once
    By kmarsus in forum Fagor Automation
    Last Post: 07-06-2015, 11:23 PM
  3. Single block
    By CNC-Span in forum SIEMENS -> GENERAL
    Last Post: 11-20-2008, 08:12 PM
  4. single block switching
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 11-11-2008, 05:18 AM
  5. Single Block problems?
    By mark c in forum Mach Mill
    Last Post: 06-15-2008, 08:11 PM
