586,761 active members*
7,698 visitors online*
    Haas Shuttle fault
    I'm having an issue with our 2004 VF-3. The proximity switches for the shuttle in and out are acting up. The switches test fine and they supply the correct voltage back to the I/O board. Though on the I/O screen they both say 1. The weird thing is that if I open the door to rear panel and wait a minute they will work right, but if i close the door I can watch the 0 turn to a 1 on the I/O screen and it will fault out. I installed all new fans and the cabinet filter thinking it was a cooling issue. I also replaced the I/O board. Still no luck. Any help would be greatly appreciated.
    2932
    Re: Haas Shuttle fault
    I've found that the SHUTTLE IN/SHUTTLE OUT RELAYS sometimes get sticky and the shuttle will time out. You night try cleaning the relay contacts or replacing the relays.
    Sep 2013
    326
    https://www.haascnc.com/content/dam/...ual---2002.pdf
    Page 354... Shows the output section .
    Page 351 .... Shows the input
    Quote Originally Posted by bahnfire18 View Post
    Thank you. I'll look into these cables.
    I think I figured it out. The new mocon board has aluminium heat sinks on one part of the board. The old one didn't. it's working fine now that I got a spare from a retired haas tech.
  1. Replies: 2
    Last Post: 01-19-2018, 12:14 AM
  2. 2000 VF-4 Shuttle Fault
    By ntcnc in forum Haas Mills
    Last Post: 10-30-2012, 02:22 PM
  3. 102,113 Shuttle fault error
    By CWC in forum Haas Mills
    Last Post: 05-22-2012, 10:26 PM
  4. Turret shuttle fault
    By jprobst in forum Haas Mills
    Last Post: 09-23-2009, 04:05 PM
  5. VF3 SHUTTLE IN FAULT
    By JACKOFTRADES in forum Haas Mills
    Last Post: 11-29-2007, 05:23 PM
