586,945 active members*
2,297 visitors online*
Hybrid View
    May 2021
    Stepper motors running opposite direction
    Good Day.
    I bought A11 Plus controller and connected it, Now the motors are running the opposite direction. All axis. i was replacing the 0401 controller. Whats the solution.
    Nov 2008
    643
    Re: Stepper motors running opposite direction
    You can reverse stepper direction by reversing two wires.
    Jan 2018
    1516
    What software program do you use to run the cnc?.
    There may be an option in the soft limits or axis pages to select 'axis reversed'.
    Sometimes it's that simple.
    15362
    Quote Originally Posted by mrejo View Post
    Good Day.
    In your Control software look for Active Low or Logic High you can change direction with this either Check or Uncheck and save
    You may find it easer to change the motor wiring
    Mactec54
    Jan 2018
    1516
    Forgot about that way of doing it. Until I knew how opto's worked I was nervy about it as a total novice.
    The way I understand it is: All it esentially does is swaps around the way the voltage is applied to direction.
    For instance:
    So if voltage isn't flowing in say active low it spins CCW, if voltage is flowing it spins CW.
    Now switch to high:
    Voltage not flowing is now CW, voltage flowing is now CCW.
    Simple as that!!.
  1. Replies: 2
    Last Post: 01-08-2020, 08:33 PM
  2. Replies: 3
    Last Post: 01-01-2019, 11:23 PM
  3. Replies: 3
    Last Post: 06-06-2017, 02:02 PM
  4. CNC problem, X goes in the opposite direction
    By tilen986 in forum Mach Software (ArtSoft software)
    Last Post: 12-15-2015, 05:30 PM
  5. Mach3 is moving in the opposite direction
    By maly-miller in forum Mach Mill
    Last Post: 03-04-2014, 03:00 PM
