586,655 active members*
3,172 visitors online*
Results 1 to 10 of 10
    Feb 2006
    992
    Cutter Compensation problem
    The rectangle I demonstrating is 2" x 4", When make part the dimension always off about .015 radius and I though I could use tool compensation to take care of it, however Mach3 give me quite a problem. If I put in .015 in tool offset diameter the machine will cut (G03 X3.1963 Y2.1759 I0.1875 J0 F25.) line on the left as shown in the picture, if I put in -.015 in tool offset diameter the machine will cut (G02 X7.1213 Y1.8509 I0 J-0.325 line on the right as shown in the picture. Does anyone know why? maybe there is some parameter in the Config that I missed?
    By the way, if i put .015/-.015 in Tool Wear under Tool Offset nothing happen, nothing I mean the machine will cut just fine but then it is defeat the point have comp .
    O0
    (MACHINE: FANUC 15MB MPost Library)
    G17 G40 G80 G90
    T1 M6
    G00 G55 X3.0213 Y2.3634
    G43 Z0.3 H1
    M9
    Z0.1
    G01 Z-0.1 F25.
    G41 X3.0088 F20. D11
    G03 X3.1963 Y2.1759 I0.1875 J0 F25. (if .015 input this line start have problem)
    G01 X6.7963 F20.
    G02 X7.1213 Y1.8509 I0 J-0.325 (if -.015 input this line start have problem)
    G01 Y0.2509
    G02 X6.7963 Y-0.0741 I-0.325 J0
    G01 X3.1963
    G02 X2.8713 Y0.2509 I0 J0.325
    G01 Y1.8509
    G02 X3.1963 Y2.1759 I0.325 J0
    G03 X3.3838 Y2.3634 I0 J0.1875 F25.
    G01 G40 X3.3713
    G00 Z0.3
    X0.025 Y1.3125
    Z0.1
    G01 Z-0.1
    G41 X0.0125 F20. D11
    G03 X0.2 Y1.125 I0.1875 J0 F25.
    G01 X1.8 F20.
    G02 X2.125 Y0.8 I0 J-0.325
    G01 Y0.2
    G02 X1.8 Y-0.125 I-0.325 J0
    G01 X0.2
    G02 X-0.125 Y0.2 I0 J0.325
    G01 Y0.8
    G02 X0.2 Y1.125 I0.325 J0
    G03 X0.3875 Y1.3125 I0 J0.1875 F25.
    G01 G40 X0.375
    G00 Z0.3
    M9
    G28G91 Z0
    G90 G00 G59
    X0 Y0
    M30
    The best way to learn is trial error.
    Aug 2009
    1573
    Re: Cutter Compensation problem
    ...need to have a Lead-in and Lead-out move XY
    https://www.cnczone.com/forums/g-cod...tter-comp.html
    Sep 2015
    12
    i notice you are using t1 and h1 but d11. is that intentional? and are you adjusting the comp in the d11 spot?
    Feb 2006
    992
    aware of that but so far it doesn't make diffirence.
    - - - Updated - - -
    Quote Originally Posted by RINES View Post
    Yes, it is program like that by design.
    Aug 2009
    1573
    ...this is not a long term fix for CAM post but, try running modified program below see if this fixes the problem...see notes.
    O99 (changed to 99 from 0)
    N10 G17 G40 G80 G90
    N20 T1 M6
    N30 G00 G55 X3.5 Y2.5 (changed XY start point)
    N40 G43 Z0.3 H1
    N50 M9
    N60 Z0.1
    N70 G01 Z-0.1 F25.
    N80 G41 X3.0088 Y2.3634 F20. D11 (added/moved to here Y)
    N90 G03 X3.1963 Y2.1759 I0.1875 J0 F25.
    N100 G01 X6.7963 F20.
    N110 G02 X7.1213 Y1.8509 I0 J-0.325
    N120 G01 Y0.2509
    N130 G02 X6.7963 Y-0.0741 I-0.325 J0
    N140 G01 X3.1963
    N150 G02 X2.8713 Y0.2509 I0 J0.325
    N160 G01 Y1.8509
    N170 G02 X3.1963 Y2.1759 I0.325 J0
    N180 G03 X3.3838 Y2.3634 I0 J0.1875 F25.
    N190 G01 G40 X3.3713
    N200 G00 Z0.3
    N210 X0.5 Y1.5 (changed XY start point)
    N220 Z0.1
    N230 G01 Z-0.1
    N240 G41 X0.0125 Y1.3125 F20. D11 (added/moved to here Y)
    N250 G03 X0.2 Y1.125 I0.1875 J0 F25.
    N260 G01 X1.8 F20.
    N270 G02 X2.125 Y0.8 I0 J-0.325
    N280 G01 Y0.2
    N290 G02 X1.8 Y-0.125 I-0.325 J0
    N300 G01 X0.2
    N310 G02 X-0.125 Y0.2 I0 J0.325
    N320 G01 Y0.8
    N330 G02 X0.2 Y1.125 I0.325 J0
    N340 G03 X0.3875 Y1.3125 I0 J0.1875 F25.
    N350 G01 G40 X0.375
    N360 G00 Z0.3
    N370 M9
    N380 G28 G91 Z0
    N390 G90 G00 G59
    N400 X0 Y0
    N410 M30
    START POINT MAYBE WRONG...ADJUST AS NEEDED
    Feb 2011
    353
    The changes that machinehop5 did should solve the problem
    I will assume you are using .0000 as the start of the radial value for the end mill
    Your starting point is X3.0213 and the move to set the cutter comp is X3.0088 this is .0125 distance that will be all that you can have for cutter comp
    after .0125 the control should say g41/g42 comp interference
    Feb 2006
    992
    Thanks everyone for the help. However, it didn't solve weird move. I have software that can be easily offset it just annoying, kept play with it I will figure it out.
    Jan 2005
    15362
    Quote Originally Posted by CNCRim View Post
    O0
    G17 G40 G80 G90
    T1 M6
    G43 Z0.3 H1
    M9
    Z0.1
    G01 Z-0.1 F25.
    G01 X6.7963 F20.
    G01 Y0.2509
    G01 X3.1963
    G01 Y1.8509
    G01 G40 X3.3713
    G00 Z0.3
    X0.025 Y1.3125
    Z0.1
    G01 Z-0.1
    G01 X1.8 F20.
    G01 Y0.2
    G01 X0.2
    G01 Y0.8
    G01 G40 X0.375
    G00 Z0.3
    M9
    G28G91 Z0
    G90 G00 G59
    X0 Y0
    M30
    Try this, you may have a problem with the G41 cutter comp activating as the moves you have in the second part of the program may not work, the move has to be at least the tool diameter
    D11 is not going to work
    O0
    G17 G40 G80 G90
    T1 M6
    G43 Z0.3 H1
    M9
    Z0.1
    G01 Z-0.1 F25.
    G41 X3.0088 P.015 F20.
    G01 X6.7963 F20.
    G01 Y0.2509
    G01 X3.1963
    G01 Y1.8509
    G01 G40 X3.3713
    G00 Z0.3
    X0.025 Y1.3125
    Z0.1
    G01 Z-0.1
    G41 X0.0125 P.015 F20.
    G01 X1.8 F20.
    G01 Y0.2
    G01 X0.2
    G01 Y0.8
    G01 G40 X0.375
    G00 Z0.3
    M9
    G53 Z0
    X0 Y0
    M30
    Mactec54
    Jan 2018
    1516
    O0
    G17 G40 G80 G90
    T1 M6
    G43 Z0.3 H1
    M9
    Z0.1
    G01 Z-0.1 F25.
    G01 X6.7963 F20.
    Heya Mactec.
    So can you interperate to me how this line works please?.
    I might need to play with it myself also.
    I've put an idea of how I think it reads. Just need you to tell me I'm stupid and correct me.
    G41- Start cuuter radius compensation (left).
    X3.0088 - X axis starting point ready for lead in.
    P.015 - Amound added to tool (0.015 larger diameter). So a P-.015 would make it smaller?.
    F20 - Our starting ffedrate.
    Thanks.
    This document from machmotion is probarbly quite a useful indepth read to many.
    Explains quite a lot on how the g-code language works:
    https://machmotion.com/documentation...-Reference.pdf
    Jan 2005
    15362
    Quote Originally Posted by dazp1976 View Post
    Heya Mactec.
    Thanks.
    No it is not normal add a - or a + sign to this number the G41 is going to move the P.015 there must be an axis move by a minimum of half the tool diameter before cutter comp will activate
    No the P0.15 will make it .015" smaller
    Using the D word can also cancel the cutter comp in some controls so may be part of his problem
    It will not activate any cutter comp unless the axis moves the right amount before engagement this is where most mess up
    Mactec54
  1. Replies: 2
    Last Post: 08-08-2014, 07:17 PM
  2. Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    By Stavros Flatly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2013, 02:48 AM
  3. Cutter Compensation Problem
    By trangt143 in forum Haas Mills
    Last Post: 04-26-2010, 08:40 AM
  4. cutter compensation
    By functionbikes in forum Tormach Personal CNC Mill
    Last Post: 06-17-2008, 08:39 AM
  5. Cutter Compensation?
    By Joe Petro in forum Autodesk
    Last Post: 03-08-2006, 07:04 AM
