Hello everyone,
I'd like to know if buck and boost transformers could be causing me to blow my X axis transistors (see my 'X axis transistor failed again' string) I have 2 Square D catalog # 500SV43F buck and boost transformers that may be pushing the voltage and currents too high mounted to the side of my BP Series I Boss 6. In the following link: http://stevenengineering.com/Tech_Su...Fs/45SPSAT.pdf mine are wired as shown in diagram 6. I think that table 9 of the linked document applies to my setup.
I think that they must have been necessary at one time, but in my shop may be causing problems. I have a Ronk Roto-Con Mark II RPC, (10 KVA, 10 total HP, FLA single phase of 53) with (2) 50 Mfd run caps wired in parallel. My output voltage from the RPC is as follows:
A-B=250 (A is the wild leg, not a line in)
A-C=228
B-C=244
Do I need these transformers??
On the output size of these buck and boost transrformers I have:
A-B=252 (again, A is the wild leg, not a line in)
A-C=275
B-C=270
Both sets of numbers are not under load. Would I hurt anything by bypassing both of these transformers, and going straight from the RPC to the contactor on the mill? Thanks for any and all help!!
Ian
