586,500 active members*
2,869 visitors online*
Results 1 to 3 of 3
    Jun 2021
    1
    2Ghz CPU Required?
    I have an older laptop with a 1.75GHz cpu that I'd like to use to drive a Smoothstepper with Mach4. Anyone running a pc with a cpu less than the recommended 2GHz frequency?
    Nov 2013
    4421
    Re: 2Ghz CPU Required?
    my machine PC is a dual core Atom single-board PC with on chip graphics. It runs at 1.86MHz. It runs Mach4 just fine.
    My little PC is well below the recommended (NFS) minimum but I've been using it for six years without problem.
    The only time I notice the lack of grunt is when or if I load a large Gcode file, say 5MB or more. Then the toolpath loads slowly,
    say a minute or more and can take another minute or so to draw the toolpath. Once the toolpath is drawn there are no problems at all.
    I would say just about any PC will work just fine.
    Craig
    Dec 2023
    1
    Using a laptop with a 1.75GHz CPU to drive a Smoothstepper with Mach4 may lead to performance issues, especially if the CPU does not meet the recommended specifications. It's important to ensure that the system meets the minimum requirements for smooth and reliable operation.bubble shooter
  1. 99% cpu use
    By JohnF in forum Mastercam
    Last Post: 08-28-2011, 11:29 PM
  2. BMC 30 CPU
    By koonyam in forum HURCO
    Last Post: 12-08-2009, 04:39 PM
  3. Replies: 2
    Last Post: 12-06-2008, 03:10 AM
  4. cpu speed
    By jc286006 in forum DIY CNC Router Table Machines
    Last Post: 08-21-2005, 02:38 AM
