586,500 active members*
1,860 visitors online*
    May 2021
    9
    R Less Than Z in Cycle in XY Plane
    Hi I generated a g-code for my drilling work but ran to this error in mach3
    "R Less Than Z in Cycle in XY Plane"
    and i don't have a clue
    this is parts of the g-code
    G90 G94 G91.1 G40 G49 G17
    G21
    G0 Z15.00
    M3
    G4 P4.0
    G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0
    X0.67 Y0.53
    X0.88 Y1.12
    X0.80 Y1.70
    X1.41 Y2.16
    X1.98 Y2.11
    X2.38 Y1.62
    X2.16 Y1.04
    X2.75 Y1.04
    X3.36 Y1.26
    NOTE: When i change r to a bigger number than z instead of going down and drill and going up it goes up and moves in down
    May 2021
    9
    Re: R Less Than Z in Cycle in XY Plane
    anyone?
    May 2021
    9
    my problem is that if z axis is vertical and when negative goes up how can i drill with this g-code? it just doesn't makes sense
    Dec 2008
    3110
    This is a repeat post, in the wrong forum .... see https://www.cnczone.com/forums/g-cod...ml#post2454726
