587,006 active members*
2,738 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > 5 axis machine setup creates weird offset in tool position DMG DMU50v
    Oct 2006
    71
    Ive got a 2000 DMG DMU50v that Ive been using with a 3+2 post that a guy wrote for me. He also wrote a full 5 ax post that creates correct tool tip moves but offsets the tool tip in X about 4" in + and about 2" + in Z. Y tip position is ok. Test part is cutting a wide chamfer on the top of a 1.25" dia cylinder. 5 axis tab set for defaults. Heres a pic of my machine setup that was recommended to use. Pretty sure that the post is OK and that the problem is the machine setup tile. Can anyone point me in the right direction?
    Oct 2006
    71
    Re: 5 axis machine setup creates weird offset in tool position DMG DMU50v
    Ive got a 2000 DMG DMU50v that Ive been using with a 3+2 post that a guy wrote for me. He also wrote a full 5 ax post that creates correct tool tip moves but offsets the tool tip in X about 4" in + and about 2" + in Z. Y tip position is ok. Test part is cutting a wide chamfer on the top of a 1.25" dia cylinder. 5 axis tab set for defaults. Heres a pic of my machine setup that was recommended to use. The dimension in Z for the 5th axis is the pivot point info from my machine parameters. This is one of the 45 deg nutated knuckle machines. Pretty sure that the post is OK and that the problem is the machine setup tile. Can anyone point me in the right direction?
    Jun 2021
    5
    thx for your answer
    May 2012
    84
    I think I can help !
    P M me with your e mail.
  1. DMG DMC103V 840D Z axis work offset is locked how to unlock?
    By markp in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-07-2022, 05:38 PM
  2. DMG DMU50V DNC
    By pdingbo in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-30-2018, 06:51 AM
  3. Setting up kinematic model parameters for DMG DMU50v
    Last Post: 12-20-2015, 01:33 AM
  4. Can I offset from Home position with this setup?
    By UserJ in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-17-2012, 07:21 PM
  5. DMG DMU50V mastercamX post
    By qtmachining in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-29-2011, 01:45 PM
