Hi
one of our Mori Seiki NV5000 mill with Fanuc 18i controller lost X,Y,Z,W(tool changer) zero reference position. I need instruction on zero referencing.
Hi
What did you do to lose the reference positions?It's easier to help if you know what caused it.
Replaced battery and wasn't connected correctly. Didn't loose any parameter just the zero reference position.
So nothing happens when you try to "home" it?
Can you run XYZ manually?With the hand wheel?
PLS CALL SERVICE CALL CENTER ASK THEM THE PROCEDURE TO DO THIS JOB(THEY HAVE PEPER LIKE I HAVE BUT MANY MANY PAGES). THEY HAVE QUITE ALOT MANY POINTS COMPLICATED, ESPECIALLY W AXIS AND Z AXIS IF YOU DO WRONG POSITION IT EASY TO CLASH A TOOL AND SPINDLE. AND YOU NEED TO CHANGE SOME PC PARAMETER TO MAKE W ZRN. I THINK THEY CAN HELP YOU IF CAN NOT GET FROM THEM EMAIL ME AT [email protected].
THANKS.
