586,753 active members*
7,271 visitors online*
Thread: Chip issue
    Apr 2021
    Chip issue
    I am looking for a solution to prevent chips from entering my coolant tank. I have a Haas 2004 mini mill with an opening of 9" w x 5" h. Does anyone know of a manufacturer of a chip basket that will fit? Any ideas appreciated.
    Sep 2013
    326
    Re: Chip issue
    The tip a buddy gave me ... I put these between the machine drain the the tup... and it's a Haas VF/4 w/ the chip pan, but it still does not work that well compared to this. After a few sessions just brush off the chips and reuse.
    https://www.amazon.com/20x30x1-Furna...%2C230&sr=8-12
    Jan 2018
    1516
    Re: Chip issue
    If you don't have much luck, don't dismiss this straigh away!
    I made a chip box for my home built machine (2 stage). Works brilliant. You could prob adapt something to use the same material for a 'proper' machine.
    I used stainless steel mesh sheets 400 micron for large chips and 200 for the fines. Way oil can clog it too quickly though so maybe 400/300 would be better.
    Empty, rinse, repeat. Easy to wipe and no worries of it rotting either.
    927
    Re: Chip issue
    Chunk of perforated metal and a couple of magnets.
