I have a PCNC 1100 making a rough cut with 3/4 rough/finish endmill. On the last cut Attachment 462290 the cutter is actually pulling the axis down so the final depth is deeper than the fixture top.
Crazy? I recheck the tool length and it is still the same. When I rehome the axis the tool will go to the correct height. for the final depth. This has started after running about 10-12 parts.
The material is 7/8 4140 annealed steel and the cutter is coated cobalt. The program is ramping the cutter at a 1 degree conventional cut.
Is it the cutter dulling? Is the cutter too large for the machine?
Oh ya, the spindle speed is 1000 and IPM 10
