586,850 active members*
2,177 visitors online*
    Mar 2012
    189
    code to enable brake?
    I am troubleshooting on my slantpro. Is there way to enable the x axis brake from the programming line so I can test it's functioning?
    -Jon
    Nov 2007
    2151
    Re: code to enable brake?
    Quote Originally Posted by maker of things View Post
    If axis power or a brake was enabled. I dont think you could move it very easy.
    My router with no power and no axis brake you can push on axis and it will move down. With power no.
    Mill has brake on z axis either way its not moving.
    Just a little insight from my machines
    May 2008
    667
    If the brake does not work, when you turn off the power, the X axis will go all the way down, which happened to me.
    Jun 2005
    656
    I don't know how it's constructed, but if it's like the 1100 Z brake, it goes on when power is cut, so difficult to do from code.
    Mar 2012
    189
    So, I could just unplug the wires to the brake at the board and the brake should be in effect. That will work for me.
    -Jon
  1. FANUC OT/MIYANO Spindle brake code?
    By WOTDesigns in forum Fanuc
    Last Post: 02-24-2016, 05:07 PM
  2. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  3. Floppy drive enable code
    By thouse in forum Cincinnati CNC
    Last Post: 05-27-2009, 05:52 AM
  4. DX 32 coolant enable G code problem
    By Ranchero50 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2008, 03:18 AM
