587,072 active members*
2,926 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > AXIS stepper/servo motor requirements, want shared components from router to mini mil
    Apr 2008
    91
    I am building both mini mills and router cnc machines and I want drive components interchangable between them. Is 3 nm a good driver for the axis' on a wood router? such as these:
    https://www.aliexpress.com/item/4000...archweb201603_
    Jan 2008
    1538
    Re: AXIS stepper/servo motor requirements, want shared components from router to mini
    Are you planning on swapping motors between machines?
    It will not be easy to mount and unmount motors and the associated wiring.
    I have shared drivers / control electronics / computer for a mill, lathe and router.
    Each machines has its own motors (all the same model steppers). I use an industrial 48pin connector to swap the connection for the drivers etc.
    Apr 2008
    91
    Quote Originally Posted by pippin88 View Post
    I don't plan to swap the motors between machines, I'm simply taking from a spares and maintenance perspective.
    Is a nema 23 3nm sufficient for a router table? I know it's enough for my mini mill
    Depends on how big the machine is, and how fast you want it go.
  1. PM Field Servo motor amplifier requirements?
    By greeder88 in forum Servo Motors / Drives
    Last Post: 04-12-2014, 08:11 PM
  2. Stepper motor kits for me requirements?
    By Mindcore in forum Stepper Motors / Drives
    Last Post: 04-20-2010, 12:09 AM
  3. Stepper Motor Power Requirements
    By GAWnCA in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2007, 07:44 PM
