586,546 active members*
3,446 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > vcarve on non-flat surface
    Mar 2019
    18
    is there any way to use vcarve method on non-flat surfaces with rhinocam?
    here is an example of what i am trying to do(at 7:34):
    https://youtu.be/rX6GO4Z3LWg?t=454 at 7:34
    and here is what rhinocam giving me, it's giving me the path as all curves on z=0
    1230
    Re: vcarve on non-flat surface
    Its a few years since I worked with Rhinocam and I rate even the most basic package highly.Are you able to run a simulation in 3D and take a screenshot of the finished piece?I can't tell very much from the screenshot provided and having the item included would be very helpful.There is a risk that the calculation of a Vcarve toolpath on a curved surface might not be totally correct as the geometry of the surface is automatically more complex than a flat,horizontal surface.I would hope this would have been factored in if you have projected the outline of the cut down onto the surface.
    Mar 2019
    18
    new screenshots added. 1st one is what i am talking about.
    2nd one is to show that non-planar curves give right result for planar surfaces, or in other words, it gives same result with planar curves.
    1230
    It appears that the outline had been projected down onto the curved surface correctly.Had you deleted or hidden the outline at the top level?
    Mar 2019
    18
    there is no outline at top level, they all projected to surface already, but rhinocam act like they are at top level.
  1. Cutting a flat surface
    By Beezle in forum Tormach Personal CNC Mill
    Last Post: 03-06-2014, 06:01 AM
  2. flat surface finishing
    By Shakalad in forum Uncategorised CAM Discussion
    Last Post: 01-09-2013, 02:13 PM
  3. Possible to bend a flat surface?
    By Seitz333 in forum BobCad-Cam
    Last Post: 09-25-2012, 09:52 PM
  4. How to have surface table really 'flat'?
    By Sentinel in forum DIY CNC Router Table Machines
    Last Post: 04-02-2008, 07:06 AM
  5. Facing and getting a FLAT surface
    By SRT Mike in forum MetalWork Discussion
    Last Post: 05-11-2007, 08:22 PM
