586,556 active members*
3,391 visitors online*
    1605 or 1610 for Inlays wood
    Need a little help. I can't decided which screw ball pitch to install for my new CNC 1605 or 1610 for Y and Z axis. It will mostly be using Inlays wood to make cutting board.
    I'm afraid 1610 will be too fast for more precise work. For example in the video below:
    https://www.youtube.com/watch?v=TBoh7E8iFgw&t=356
    Thank you
    Jul 2018
    6410
    Re: 1605 or 1610 for Inlays wood
    Hi Boris - The machine feeds at the programmed speed no matter what the pitch is. 5mm gives huge forces whereas 10mm will give better speed if you need it. Its easier to slow down a machine then speed it up.... Peter
    Thank you
    Nov 2012
    1267
    Are the ballscrews directly coupled to the stepper motors? In that case I would choose 1610. That would give fast rapids and plenty of precision (0.05mm per full step).
    Thank you
  1. Can a cnc router cut as fine inlays in wood and cut veneer for the inlay
    By videorov in forum Uncategorised WoodWorking Machines
    Last Post: 05-22-2017, 11:32 PM
  2. Have you made any wood inlays with this machine?
    By videorov in forum Thunder Laser
    Last Post: 05-07-2017, 12:47 AM
  3. Wood Made In USA Sign with PVC letter inlays
    By CNC602 in forum Portfolio Board
    Last Post: 06-18-2015, 04:37 PM
  4. Wood Inlays
    By highwaymancnc in forum EdgeCam
    Last Post: 04-25-2011, 01:22 AM
  5. Ballscrew 1610 2m
    By kostas1 in forum DIY CNC Router Table Machines
    Last Post: 10-11-2009, 01:11 AM
