Re: Haas editing question
Go to your program and hit edit. That will bring up the program in a smaller box and a list of available functions above. Press F1 and that will bring up the sub functions. Arrow over to SEARCH and hit and hit the WRITE/ENTER button. (that's the button on the far right lower corner of the panel.) There is an offered function that says something like find and replace. Hit the WRITE/ENTER button again. Just kind of follow the instructions from there. It will ask you to select the text you want to replace ans enter the text you wish to replace it with. It will ask you if you want to change that one or all. If you choose all "A", it will replace of that match.
Good luck-----Mike
