586,655 active members*
3,610 visitors online*
    Mar 2021
    Mitsubishi m700 Marco
    Hi everyone.
    We have a Wuhan CH5116B Vertical Lathe machine with Mitsubishi M700. We have an issue with ATC. Can anybody explain me, how can I use PLC devices with global variables to create a macro for tool change?
    I found some information about variables #50000-52749. By using these variables, I can read data from R8300-R29799, but unfortunately it doesn't work at all.
    My LADDER looks like.
    TF1-------------[MOV R536 R8300]
    O7755()
    (test)
    #2=#50000 (R8300, R8301)
    IF[#2EQ1]GOTO10
    N10
    #1=30
    N300
    G53G00A#1
    Thank you in advance.
    Sep 2010
    1230
    Re: Mitsubishi m700 Marco
    Quote Originally Posted by got2be View Post
    Hi everyone.
    O7755()
    (test)
    IF[#2EQ1]GOTO10
    N10
    #1=30
    N300
    G53G00A#1
    Hello got2be,
    For a start, your program code is flawed. The Conditional Statement "IF[#2EQ1]GOTO10" is irrelevant; the program will execute the same way whether the Conditional Statement is included or not.
    In the above program, if #2=1. then the Conditional Block will test True and the program would branch to N10, which happens to be the Next Block. If #2 doesn't equal 1, then the Conditional Block will test False and therefore will not specifically branch to N10. When the Conditional Statement tests False, the program will simply step on to the Next Block, which just happens to be the N10 Block. Accordingly, the program executes in the same way irrespective of the value of #2.
    Bill
    Mar 2021
    Quote Originally Posted by angelw View Post
    Hello got2be,
    Bill
    Thank you Bill
    I found a way how to use these variables, but right now I'm looking for Register in PLC of the axe direction (CW or CCW). Anyway thank very much.
