586,655 active members*
4,097 visitors online*
    May 2007
    Thread Measuring
    Guys, whats the formula to find the thread of say a grinding wheel spindle ( 10" dia) i need to make a new flange to mount on it to accompany a balancing head on the wheel. I need to find what type of thread is on the spindle to make the new nut.
    thanks,
    Aug 2007
    65
    Don't you have thread pitch gauges? You can find the at your local hardware store, and they come standered with tap and die sets.
    Make sure you clean my wrench before you put it back into my toolbox.
    Mar 2006
    2712
    krismcneil, Your profile says "man. eng.". Is that the same as Manufacturing Engineer (Mfg. Eng.)? If so, you are going to need "the source", Machinery's Handbook, which contains thread formulea, thread measuring methods and most everything else you will eventually need concerning machining. If you don't have a copy, I'd strongly suggest getting one.
    DZASTR
  1. Measuring FTT and OEE in CNC Shop
    By WayneHill in forum MetalWork Discussion
    Last Post: 06-30-2011, 04:09 PM
  2. Asimeto measuring tools?
    By Chuck Reamer in forum Calibration / Measurement
    Last Post: 02-15-2008, 03:26 PM
  3. Measuring following error
    By eldata in forum Mach Mill
    Last Post: 02-23-2007, 03:54 PM
  4. Measuring Gears
    By Flyinfool in forum MetalWork Discussion
    Last Post: 05-24-2006, 09:02 PM
  5. Measuring question?
    By pstockley in forum MetalWork Discussion
    Last Post: 02-04-2006, 01:14 AM
