586,547 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > left handed tools in the lathe turret?
Results 1 to 7 of 7
    Jan 2012
    57
    Hi guys, can anyone confirm that this video has left handed tooling in the turret?
    I'm new to this and am trying to avoid getting the wrong tools.
    thanks in advance!
    Feb 2011
    353
    Re: left handed tools in the lathe turret?
    those should be right handed tools
    Dec 2013
    5717
    Yup, right hand tools. But depending on the part and setup, I sometimes use left hand tools if I want to come in on a back face or something like that. But for most turning; right hand.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2012
    57
    Thanks guys!
    AutomateCNC tells me the turrets are setup for 20mm lathe tooling, can you guys recommend a place to get a good tool set? Assume I'm starting from zero and need a little of everything and looking specifically for carbide insert tool holders.
    I see the 3/4 inch tools are far more common but I dont want to shim it.
    Dec 2013
    5717
    My lathe is set up for 20mm also, but I just use shims and 3/4 shank holders. I went to Harbor Freight and picked up a half dozen feeler gauge sets to have a nice shim assortment. Works great.
    I bought Accusize holders from Amazon to get started. 2 years and thousands of parts later I'm still using them. https://www.amazon.com/AccusizeTools...s%2C222&sr=8-2
    The Accusize parting tool is not great for CNC work and didn't live long, so I bought an ISCAR parting tool holder, not cheap but very good. https://www.iscar.com/eCatalog/Item....FSTYP=I&srch=1
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2012
    57
    Thank you Jim, I appreciate the pointers. I struggled with the left/right tooling until I found this diagram and then it made sense.
    I just saw your location as Sandy Oregon, I used to drive through Sandy, Boring and Estacada to my shooting spot in the foothills of Mount Hood.
    I lived in Oregon for 16 years. Fond memories.
    Dec 2013
    5717
    My pleasure.
    After running manual lathes for 50 years it took me a bit to look at the world upside down in a CNC turret lathe. Then it finally dawned on me that the carriage was just rotated around the spindle about 140 degrees. Two years ago I couldn't even spell CNC lathe
    Jim Dawson
    Sandy, Oregon, USA
  1. Left Handed Threading on a Grizzly G0602 10x22 Benchtop Lathe
    By BigSmith in forum Benchtop Machines
    Last Post: 10-11-2012, 05:34 PM
  2. Handed Parts Left/Right
    By seijack in forum UG NX
    Last Post: 12-20-2010, 10:52 PM
  3. Replies: 19
    Last Post: 04-08-2010, 06:06 AM
  4. left handed rope thread
    By GeorgN in forum MetalWork Discussion
    Last Post: 04-08-2010, 05:29 AM
  5. Right or Left Handed?
    By Asinity in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2008, 08:04 PM
