586,477 active members*
1,894 visitors online*
Results 1 to 15 of 15
    Dec 2005
    51
    heidenhain monitor volts
    Does anyone know the voltage going to the monitor for a series 1 with heidenhain 151 control?
    1121
    I know it is an inverted hercules monochrome signal, and the control runs on 120 volts, but never checked what the operating voltage is
    Dec 2005
    51
    thanks I think that will help me get started with fixing it.
    24223
    The majority of older CNC monitors are TTL , also in many cases the horizontal oscillator will not run with out the H. Sync signal present. (blank screen).
    Al.
    1121
    The manuals on the heidenhain site will tell you the pinout of the monitor, but nothing on monitor guts. If the control is not putting out video, it is the video chip, available pretty cheaply, if that is the case I will go get the number for you
    Nov 2006
    925
    I believe the 151 monitor uses about 11 volts dc.Some have an onboard power supply but it sticks in my mind that some get it from a card.
    Mark.
    Jan 2004
    185
    I have a Beaver mill with 150 control and a blank screen voltage 240 volts at monitor
    BR
    Nov 2006
    925
    Brian,here is the link to the 150 maintenance manual.If you look at the flow chart for testing the vdu you will see it has an 11 volt supply.If you have 250 volts at the monitor I can understand why it`s not working.Are you sure the 250 volts is not the supply to the Heid box which has another power supply inside it for reducing the voltages.
    http://filebase.heidenhain.de/doku/o...0/gb/sa150.pdf
    Mark.
    Jan 2004
    185
    mark, 240v to control and 240v to vdu model 114 I think
    sent monitor to omi-monitors.co.uk repair £70 if I need a new tube add £80.
    a lot better than £445 for a recon.
    Brian
    BR
    Jan 2004
    185
    I still have an old BBC monitor that I might try to hook up. a chap from a well known repair company admitted to using BBC monitors in some cnc machine repairs
    BR
    Nov 2006
    925
    Brian,there`s a psu in the vdu that drops the volts to 11.
    I give my monitors to a local tv guy.Last one was £40,one before it was £30.No packing,put it in motor,drive to the shop,get it back two days later.
    Jan 2004
    185
    Mark ,next time I will it blanks out I will phone
    by the way it was the PSU that needed repair
    BR
    Jan 2004
    185
    thanks gridley 51
    thanks,
    the guy did fix the monitor £40
    heidenhain no longer supplies 145,150,151 monitors and offer touchscreens £1500 so grab any monitors for spares
    BR
    Nov 2006
    925
    Brreid says,
    "heidenhain no longer supplies 145,150,151 monitors and offer touchscreens £1500 so grab any monitors for spares"
    Brian,does that mean I should buy that one that`s on Ebay just now? :-)
    Mark.
    Jan 2004
    185
    No Mark,
    because you dont have a 145 Heidenhain control and I wouldn't like to see you waste money
    BR
  1. Need a monitor replacement - Heidenhain TNC 2500
    By litestat12 in forum Bridgeport / Hardinge Mills
    Last Post: 05-01-2007, 11:03 AM
  2. THC torch volts?
    By turboboy in forum Waterjet General Topics
    Last Post: 10-06-2006, 12:41 AM
  3. 5 volts to 1.5 volts?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 08-18-2006, 11:18 AM
  4. Boosting three-phase 240 Volts to 480 Volts
    By Old Car Guy in forum Phase Converters
    Last Post: 05-01-2006, 03:27 PM
  5. 24 Volts from Computer PS
    By Jason Marsha in forum CNC Machine Related Electronics
    Last Post: 01-19-2006, 04:19 AM
