587,051 active members*
3,695 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
Results 1 to 14 of 14
    Nov 2008
    37
    Hi, we need you help to solve my problem on Fanuc Oi-D alarm "SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR" suddenly appear after about one hours running. Attached are the picture of alarm
    Aug 2011
    420
    Re: FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
    I think , real alarm/error is
    PC050 IOLINK ER1 CH1:GR00:03
    "Imagination is more important than knowledge."
    Nov 2008
    37
    Quote Originally Posted by kurmay View Post
    What does it mean?
    Aug 2011
    420
    I don't know but it seems PLC error.
    Dec 2009
    967
    one of the I/O device is offline,maybe a fuse blown on the device,possible you have a short somewhere on the wires
    Oct 2009
    297
    Quote Originally Posted by mluqman View Post
    Check the position of the axes when the alarm appears. It could be an intermittent short circuit . This is why the alarm PC050 IOLINK ER1 CH1:GR00:03 appears. If it happens even when the machine is not running, probably a bad PSU in the PLC rack.
    regards
    AlexFanuc
    Nov 2008
    37
    Quote Originally Posted by alexfanuc View Post
    regards
    AlexFanuc
    I shutdown the machine and ON again after that the alarm PC050 IOLINK ER1 CH1:GR00:03 not appear anymore (like normal booting) but alarm display in the following
    OT alarm
    Turret alarm
    Emergency alarm
    I checked X input on the io status all the bits 0 that means the io not working.
    whe
    Dec 2009
    967
    look on the PMC Maintenace screen, on the I/O LINK screen ad show us what you have there.
    Nov 2008
    37
    Quote Originally Posted by zavateandu View Post
    Case close, the io at control panel defective
    thank you to all of you
    Mar 2021
    12
    输入输出单元的线短路了
    Apr 2021
    2
    YOU CAN SHARE US MORE INFORMATION ON THE REPAIR OF THE FAILURE.
    Apr 2021
    2
    HELLO COULD YOU HELP ME, I HAVE THIS INTERMITTENT ALARM IN MY MACHINE ..... FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR .... WE RESET IT AND RESET BUT STILL WE CANNOT FIND ANY SHORT OR FUSE DAMAGED
    FANUC SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR results
    - - - Updated - - -
    Mar 2022
    1
    Hi!
    How could you find the failure?
    I had a similar mistake in a fanuc controller, I check I/O link controller but nothing seems weird
  1. Fanuc system 3T F error
    By zone7 in forum Fanuc
    Last Post: 06-23-2020, 10:49 PM
  2. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  3. Fanuc 10 System Error E
    By nordlichtFanuc in forum Fanuc
    Last Post: 11-10-2018, 07:59 PM
  4. Doosan Lynx 300 System Software Error
    By ss101504 in forum Daewoo/Doosan
    Last Post: 02-04-2017, 01:52 AM
  5. Replies: 2
    Last Post: 06-08-2007, 05:42 AM
