586,133 active members*
3,855 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Mill Turning on your Tormach 1100 PCNC?
    Jul 2008
    81
    I want to do some mill turning on my Tormach 1100 S3. I have watched a number of YouTube videos and tried to learn as much as I can before attempting
    to Mill Turn a part or two. Has anyone on the forum run their 1100 PCNC for Mill Turning? I am using Fusion 360 and went through their multi chapter tutorial
    on regular lathe turning as well.
    My main concern is changing the post processor file in Fusion. I have watched NYC CNC's video on this too.
    Here is a list of some resources for anyone else considering this operation that I found helpful.
    Lucas is busy a YouTuber videos. He discusses changing the Post Processor setting to allow lathe ops.
    VAR = turning =(currentSelection.getType() **TYPE_TURNING)
    Jason Hughes videos on mill turning
    https://www.youtube.com/watch?v=qQOpOq1Ce8o&t=349s
    Eric Colvin's videos
    https://www.youtube.com/watch?v=7EOENs38kCo
    Dragon Innovations YouTube video
    https://www.youtube.com/watch?v=lIUSjH23Gio
    Dragonwrath Innovations quote from comments on his video:
    4 years ago
    Very good question, wasn't sure if I had mentioned in videos.
    In 360 select the post processor you want to use and click
    open config. control - F to 'find' and look for 'xformat'.
    There will be a scale: value, it is likely set to 2 in your
    case. Set it to 1 and you should be good to go! Thanks for watching
    John Grismo
    https://www.youtube.com/watch?v=WtaPb7A6IqM&t=0s
    Lars Fusion 360 Mill turn
    https://www.youtube.com/watch?v=xGy2FL2ft2w
    Mar 2020
    218
    Re: Mill Turning on your Tormach 1100 PCNC?
    Just saw (I assume) your post on the facebook group. In case you didn't see it there, here's the post I put together for exactly this purpose: https://www.cnczone.com/forums/torma...8-tormach.html
    Jul 2008
    81
    Thanks you for your help! I will take a closer look at this earlier post and see whether it solves my issue. Will report back to the forum. Cismontguy
    Jul 2008
    81
    Hello Soofle616, can you message me through either this forum or Facebook when you have a chance. Thanks. Cismontguy
    Jul 2008
    81
    Was finally able to find the time and run some test Mill Turning on the Tormach 1100 S3. Came out really great in Aluminum. Final parts will be in brass.
    Thanks for everyone who helped. Cismontguy.
    May 2018
    13
    Quote Originally Posted by cismontguy View Post
    Hi ! I was following Jason's videos on how to setup a Tormach 440 for millturning, but the second part is nowhere to be found. Actually, if you try to browse his Youtube channel it comes out empty. However, If I follow your link I can see the video for part 1. Do you have a link for the second part of the video? Thanks for your help !
  1. Tormach PCNC 1100 CNC Mill Package
    By weh22003 in forum Tormach Personal CNC Mill
    Last Post: 08-25-2017, 08:46 AM
  2. Replies: 18
    Last Post: 09-23-2015, 06:49 AM
  3. Tormach PCNC 1100 4 Axis CNC Mill
    By harry8 in forum For Sale Only
    Last Post: 05-18-2015, 08:01 AM
  4. Tormach PCNC 1100 VS. SmithyCNC 1240 Bed Mill... Which one and Why?
    By segal.arye in forum Tormach Personal CNC Mill
    Last Post: 07-20-2010, 12:14 PM
  5. Replies: 2
    Last Post: 07-20-2010, 11:48 AM
