587,012 active members*
3,702 visitors online*
Results 1 to 13 of 13
    Jan 2007
    11
    Rotary attachment for ULS Laser
    I just bought a generic DIY rotary attachment for use with my Universal Laser X2-600 CO2 cutter/engraver. The attachment comes with a connector with 4 pins (required for a 2-phase stepper motor) but my laser has a 9 pin connector (DB-9-F) that a rotary plugs into.
    Does anyone know the pinouts of ULS' rotary attachment? (I'm an electrical engineer and can make an adapter but need to know the connections). I'm guessing a minimum of 4 connections are required for the motor plus maybe 2 more to tell the laser that a rotary is plugged and maybe 2 more for the home position. I've asked ULS but no reply.
    Any help would be appreciated.
    Nov 2008
    643
    Re: Rotary attachment for ULS Laser
    DB9 connectors are very common for use with 4 wire stepper motors. Can’t you trace the connector wires back to the stepper drive? I’ll also bet the setup matches the other axis steppers. Use coil resistance to discover which pins are used.
    Jan 2007
    11
    Thanks for the reply. I thought of that but looking at the connector, back to the drive electronics won't tell me much. I would need to look from the drive to a connected motor in the rotary (which I don't have yet). The other 3 stepper motors (X,Y,Z) don't use DB-9s so can't use that. I've even tried to act like I have a rotary hooked up and in use and try to see 2 pin-pairs trying to drive the 2 coils of a motor but get nothing. There might also be other pins in the DB-9 that produce a home index function from the rotary plus maybe 2 other pins that actually tell the laser's computer if a rotary is plugged into the DB-9.
    Nov 2008
    643
    Not sure about the index question. I don’t know why a rotary axis would have an index or home.
    Gecko used DB9 for many years and the four pins are 6 -9. If you don’t get an answer just try to connect a cheap nema 17 in various combinations.
    Jan 2007
    11
    Thanks I'll try those pins.
    Index would tie a CAD drawing position to a repeatable rotation position. But not absolutely necessary.
    Jan 2007
    11
    Update: I built a small switch and holder (4 Pole, double throw, 4PDT) to switch between the Y-axis and my 3rd party rotary axis. Works fine except for one rotary version that was equipped with the wrong stepper motor that trashed my CPU/Motor Driver PCB!!!. The laser mfr couldn't fix it plus laser machine was out of date so they didn't have replacement PCBs :-( Be careful what you hook to your machine!
    Jan 2007
    229
    [QUOTE=MikeSinclair;2440283]Update: I built a small switch and holder (4 Pole, double throw, 4PDT)
    Hi Mike, I have an old ULS M-300 with rotary, and the RF tube is dying, but I need to get some mugs lasered, and was thinking of trying to do as you are suggesting, and use the ULS rotary in a Ruida machine.
    (We have a big flatbed one)
    I also bought a 4 pole double throw switch, to put on the Y axis drive, so I could more easily change between a future rotary device, and the Y stepper.
    Did you figure out the pin-out diagrams in the end?
    Our ULS has a 9 pin serial plug. iI was told that some of the 9 got to an onboard PCboard that tells the ULS CPU that the rotary device has been plugged in.
    Also I was told that voltages may be nonstandard...?
    Jan 2007
    11
    [QUOTE=Stewey;2483216]
    Quote Originally Posted by MikeSinclair View Post
    Jan 2007
    11
    WARNING!!! Don't do as I described and enable switching between stepping motors with power on!!! You'll risk burning out the CPU and/or Driver pcbs.
    They should only be switched with power off.
    I never got the pinouts for the DB-9 Connector ??
    Jan 2007
    11
    [QUOTE=MikeSinclair;2483450]See my post today, 11/29/21, Mike
    Jan 2007
    229
    Thanks. Actually I looked at our big Chinese flatbed, and the drives are all 3-phase stepper signalled (U,V,W), whereas the X & Y on the ULS are 2-pole steppers (A+, A-, B+, B-) so I can't convert as a quick fix.
    But yes, I'm aware you need to power off before changing Y to rotary and back!
    Thanks for the reinforcing of the notion !
    Jan 2007
    11
    Quote Originally Posted by Stewey View Post
    YES, I repeat the possible error condition - don't install/plug/connect or remove/uninstall/un-connect any stepper motor with the laser powered up! I accidently did this through a transfer switch to swap the Y-axis motor with a rotary Stepper motor and it fried both the CPU and driver boards! ULS couldn't repair them so I am Laser-less and searching for a CPU and Driver board for the X12-600. Don't do as I did!
    Sad Mike
    Jan 2007
    229
    Ouch!
    Thanks for the repeated warning !
  1. Which rotary attachment to buy from wk laser
    By wolfau in forum G.Weike Laser
    Last Post: 01-09-2015, 03:20 AM
  2. Rotary attachment for ebay laser?
    By custombuilt15 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-05-2015, 09:24 AM
  3. Rotary attachment for JQ laser
    By sr666 in forum Laser Hardware
    Last Post: 08-19-2013, 09:04 PM
  4. New laser Rotary Attachment on Indiegogo.
    By giacc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-05-2013, 01:23 PM
  5. Unversal Laser Rotary Attachment
    By zittware in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-05-2013, 05:42 PM
