586,546 active members*
3,375 visitors online*
    Jan 2014
    12
    Wiring adapter for 220v 50w laser doesn’t make sense
    My 50w laser just arrived. I know that it is 220v. I look at the PC power supply and it says 220v AC. The power cord that came with the unit has a Jack Contact 3 pin connector on one end (P20K3Q) that plugs into the unit. The other end, I expected to have a large 220v connector, but instead it has normal looking 110v prongs. I assume I need to cut the end off and use a new male end but I have no idea which is the hot wire? I peeled the cord case back and it has a black, white, and green but I don’t know which is which? Am I over thinking this?
    Attached Thumbnails Attached Thumbnails 095B3717-CAD7-4E50-9C71-8D99CFF7BEEB.jpg   89F3A674-E601-4DD1-A3DD-736C45E8F5B9.jpg
    Jan 2008
    940
    Re: Wiring adapter for 220v 50w laser doesn’t make sense
    White and black will be hot and green is ground 220 does not use a neutral
  1. New to DIY CNC. Do these parts make sense?
    By azb_ in forum DIY CNC Router Table Machines
    Last Post: 11-18-2017, 03:58 AM
  2. Replies: 8
    Last Post: 12-21-2014, 01:49 PM
  3. Cant make sense of this light stack wiring
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-25-2011, 03:49 AM
  4. Does it make sense?
    By vinybinder in forum Mechanical Calculations/Engineering Design
    Last Post: 06-24-2010, 05:42 PM
  5. Does this make sense??
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 12-29-2005, 07:28 AM
