Dear all
We have one turning center having fanuc OT controller it shows message 2001 spindle fault,then i checked drive it shows alarm 01 - motor over heat so please help me how to solve this problem.
regards,
suresh
(nuts)
Dear all
regards,
suresh
(nuts)
If the motor or machine in general is not overheated, it may be one of the Thermal sensors faulty, there is often one built into the motor, two leads coming out which should have zero resistance, occasionlly one in the spindle supply transformer is used, it is buried in the winding.
Al.
thanks Albert E
as per ur guidence i checked motor pulse coder and thermal sensor wire i found one wire RB from pulse coder disconnected after connecting it m/c working ok
thanks once again
regards,
suresh
