586,485 active members*
2,188 visitors online*
Thread: master cam x
    Aug 2006
    119
    master cam x
    Hi i have access to master cam x.. and i want to get g code for Mach 3???
    OK i have a post processor text file. then go to file and save as PST file. then were do i put it in Mach 3. then when i have the part in master cam x what file do i save as to get to Mach. and were do i put the part file in Mach
    Aug 2005
    276
    draw your part in MC-X create a machining or cutting file using toolpaths options.
    Once you have a tool path select "post" option, this will create a *.NC file an will probably be saved im masterCam\Router\NC directory.
    Next step is to open Mach3 and select "load G-code" a window will pop-up and you will need to brouse for you *.NC file (You might need to change the displayed extention from *.tap to *.* or as we know it is *.NC just select *.NC
  1. Anyone heard of CNC Master?
    By ianrobertson in forum Commercial CNC Wood Routers
    Last Post: 11-20-2008, 03:41 AM
  2. Master Jaw System?
    By elaganis in forum Haas Lathes
    Last Post: 06-23-2007, 10:34 PM
  3. CNC Master
    By Paul in OK in forum Benchtop Machines
    Last Post: 11-15-2006, 08:13 PM
  4. Master cam to Techno
    By cadfish in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-06-2006, 09:47 PM
  5. How well does master cam
    By johnm in forum Mastercam
    Last Post: 06-02-2003, 05:06 AM
