586,822 active members*
3,363 visitors online*
Page 2 of 3 123
Results 21 to 40 of 47
  1. #21
    Dec 2008
    740
    Re: Hand Pendant code .
    Quote Originally Posted by vmax549 View Post
    I am using mux2 because PP does not have a Mux4 component.
    I've just noticed that mux4 has been in the PP distribution since v2.2.0. Which version are you using?
    Step
  2. #22
    Oct 2005
    1145
    My test PC is running on 2.0.0 IF I upgrade then PP crashes the video. This is just a testing platform and the only pc out of the 6 here that will run PP . THe rest crash the video on startup.
    (;-) TP
  3. #23
    Oct 2005
    1145
    Looking at Mux4 it still will not do the rotary switches properly for the pendant. 4 inputs and 4 switches with each switch selection applying a separate value . The sample pendant code I have uses mux4 and assumes that each switch can select a separate value but that is not how mux4 seems to work.
    (;-) TP
  4. #24
    Dec 2008
    740
    (;-) TP
    You really should be looking at upgrading somehow. There's a BIG, BIG difference between 2.0.0. and 2.7.2.
    (;-) TP
    If I correctly understand what you want to do, you achieve it with a mux4 and two "or2" gates.
    From your 4 digital inputs 0, 1, 2 and 3, ignore digital input 0 (believe me!). For the first or2 gate take or2.in0 and or2.in1 from digital inputs 1 and 3, connect or2.out to mux4.sel0. For the second or2 gate take or2.in0 and or2.in1 from inputs 2 and 3, connect or2.out to mux4.sel1.
    This will convert your 4 individual inputs into a binary value (disclaimer - analyzed but not tested).
    Give it a try.
    Step
  5. #25
    Oct 2005
    1145
    I had a friend fix the video problem and did some more testing with Mux4 and found out that you cannot do a hand pendant in PP BECAUSE tormach when they added their pendant code created the link to the axis scale and now you cannot access it from hal as it was already assigned to their jog process . EVEN though this machine does not have the control panel . So unless tormach chages their code to only link to the jog scale IF there is a hooked up then we cannot add our own jog pendant. (;-) V2.0.0 did not have this problem.
    I would like to test your code idea but I have no idea how to write that code. IF you have a moment to code it I have time to test it here..
    (;-) TP
  6. #26
    Dec 2008
    740
    (;-) TP
    Here we go:
    (You will obviously need to change the Mesa pin designations "hm2_[HOSTMOT2](BOARD).0.gpio.02X.in" to be compatible with your interface and pin outs)
    Code:
    # Load the mux4 and two or2's
    loadrt mux4 names=mux-axis-scale
    loadrt or2  names=or-mux-in0,or-mux-in1
    # Add the components to the servo-thread
    addf mux-axis-scale servo-thread
    addf or-mux-in0     servo-thread
    addf or-mux-in1     servo-thread
    # Connect the scale inputs 0 to 3 to the or2 inputs:
    net scale-select-input0   hm2_[HOSTMOT2](BOARD).0.gpio.026.in   # No need to connect it anywhere. You could leave this line out.
    net scale-select-input1   hm2_[HOSTMOT2](BOARD).0.gpio.027.in   or-mux-in0.in0
    net scale-select-input2   hm2_[HOSTMOT2](BOARD).0.gpio.028.in   or-mux-in1.in0
    net scale-select-input3   hm2_[HOSTMOT2](BOARD).0.gpio.029.in   or-mux-in0.in1 or-mux-in1.in1
    # Connect outputs of the or2 components to the mux4:
    net mux-selection0   or-mux-in0.out   mux-axis-scale.sel0
    net mux-selection1   or-mux-in1.out   mux-axis-scale.sel1
    # Set the scale values for the axis multiplexer:
    setp   mux-axis-scale.in0   0.000025
    setp   mux-axis-scale.in1   0.000250
    setp   mux-axis-scale.in2   0.002500
    setp   mux-axis-scale.in3   0.025000
    # Connect the mux output to the axis jog scales:
    net axis-jog-scales   mux-axis-scale.out   axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale axis.3.jog-scale
    I presume you don't expect to integrate a Tormach Console so just comment out the axis.X.jog-scale inputs in the offending hal file:
    Code:
    net console-jogscale turbo-console.0.step-select-value #axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale axis.3.jog-scale
    I tested it on my test machine. PP runs and the axis.X.jog-scale values change according to the selected inputs. I can't however verify whether the jogging actually works.
    Give it a go if you have time.
    Step
  7. #27
    Dec 2008
    740
    net scale1 mux2.0.sel0 <= hm2_7i80.0.gpio.049.in
    net scale2 mux2.0.sel1 <= hm2_7i80.0.gpio.050.in
    Just a thought, my code assumes the gpio inputs are normally low, going high when selected. Is this the way you have them or are they normally high, being pulled down by the switch when selected?
    Step
  8. #28
    Oct 2005
    1145
    I have no idea if the inputs are active high or low. I will have to check .
    Testing the code as is when I select any switch position the value is always the same it is the last value .025 BUT if I change all the inputs to NOT then selections do work BUT the switch states are backwards true turns it off and false turns it on
    (;-) TP
  9. #29
    Dec 2008
    740
    (;-) TP
    I'm sorry but I don't quite follow your explanation...
    If the original code doesn't work as expected try changing the or2 components to xor2. The main hal file already has an xor2 so you'll have to add them to the list there:
    Code:
    loadrt xor2 names=probe-active-hi-lo,or-mux-in0,or-mux-in1
    Then delete, or better comment out the line:
    Code:
    This should reverse the sense of the inputs.
    Step
  10. #30
    Oct 2005
    1145
    OK that worked by using the Xor2. Thank you so very much for the help. The pendant jogs extremely smooth just like it should and each step precise. Now I have to work on the FRO and SSO. I still have not figured out how to push the values to the sliders and labels. But at least it is useable now.
    Thanks Again for all the help (;-) (;-) TP
  11. #31
    Dec 2008
    740
    Super, glad to hear you‘re making progress.
    Step
  12. #32
    Oct 2005
    1145
    Hi Guys I finally received the hand jog pendant and have it all hooked up and running now. It is smooth , precise and responsive. The pendant is a MPG-2 model from CNC4PC.and I used the C22 pendant interface card to plug it into the Mesa 7i80 . Pretty much plug and play for the most part. Peter at Mesa provided a new BIT file to match the pinout of the C22. It comes with a magnetic back and a steel hanger bracket. It also has a nice coiled retractable cable.
    I will update after some more testing.
    (;-) TP
  13. #33
    Nov 2007
    2151
    Sweet!
  14. #34
    Apr 2013
    1788
    Has anyone explored the interface to the rather expensive Tormach Console? From a very quick look it appears to connect to PP as a USB HID device.
  15. #35
    Dec 2008
    740
    Quote Originally Posted by kstrauss View Post
    I thought there was another post I've had quite a good look at it but I don't like HID devices (in general). It certainly would be possible to create a compatible device and have access to all the features of the console and pendant with the exception of Stop and Reset (if I remember correctly). I actually bought a Teensy specifically to have a go when I've nothing else to do (I just can't resist a challenge).
    My USB Pendant is based loosely on the Console but doesn't connect as a HID, and as you may have noticed uses a shuttle encoder because I find them FAR easier to use than the large pendant encoder wheels.
    Give it a try!
    Step
  16. #36
    Oct 2005
    1145
    When I talked to Tormach about their pendant they said it used a special board and was not available except with a console. That is why I worked to adapt a jog pendant to my machines. Having the pendant do XYZA jogging and FRO and SSO means I do not need it built into the console. It serves a duel propose remote jog pendant and when stuck to my console it is a mpg and FRO and SSO. AND it did not cost $2000.
    Just a thought. (;-) TP
  17. #37
    Apr 2012
    161
    (;-) TP
    Have you done your testing? If it works I'd really appreciate instructions on implementing this.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
  18. #38
    Oct 2005
    1145
    I will have an update soon.
    (;-) TP
  19. #39
    May 2019
    5
    Tried to make a self-made control panel. It turned out 16 buttons, three turn switches, mpg wheel, hat-switch for quick movement for lathe.On buttons you can visit any buttons in Pathpilot. MPG moves four axes and serves to adjust the speed of movement, changes spindle, processing speed and TD.The program is written for Stm32 Board. Driven through the hidcomp component.
    https://youtu.be/ELm5xddZaEE
  20. #40
    Nov 2012
    591
    That looks pretty feature packed :-)
Page 2 of 3 123
  1. Acramatic A2100 Hand Pendant
    By igoratoyan in forum Cincinnati CNC
    Last Post: 03-12-2015, 02:18 PM
  2. Acramatic A2100 Hand Pendant
    By igoratoyan in forum Machinery Manuals / Brochures
    Last Post: 02-09-2015, 12:30 PM
  3. Any Arduino Hand Held Pendant Code?
    By herring_fish in forum CNC Machine Related Electronics
    Last Post: 04-19-2011, 07:04 PM
  4. New Hand Control Pendant for MACH
    By Torchhead in forum News Announcements
    Last Post: 09-29-2010, 02:52 AM
  5. Want to Make a Hand Pendant from a Gamepad
    By glentner in forum Benchtop Machines
    Last Post: 03-16-2010, 08:47 PM
