586,655 active members*
2,503 visitors online*
    Aug 2005
    300
    electrically actuated drawbar
    Hi everyone,
    I am wondering if anyone has added an electrically actuated drawbar to their Tormach PCNC1100 ? I am interested in this because i feel that it is simpler to make and cheaper to operate . Also if anyone has done this will you share pictures and or details ?
    Ernie
    Apr 2013
    1788
    Re: electrically actuated drawbar
    A drawbar requires a pull of perhaps 2000 pounds or more. I've seen designs that use a small gear motor. Is that what you mean?
    Apr 2010
    60
    the Pneumatic drawbar seems to me to be about as simple as it can be, it can be done with all pneumatic button or pedal, cylinder, and draw bar with bellville washers. With a little more you can control it by the controller. It seems as an electric version would be more of a problem.
    I made one for a 440 it was a pretty straightforward project and all in cost was about $200.
    Aug 2005
    300
    kstrauss ,
    Yes this is what I was asking about . No requirement for a air compressor .
    Ernie
    Apr 2013
    1788
    I cannot imagine running my shop without an air compressor but...
    See https://www.cnczone.com/forums/news-...-software.html and other postings by SCzEngrgGroup for information on his design.
    Sep 2009
    624
    Scott Mulkerin (SDM Machine) developed a hydraulic cam actuated drawbor for his 1100 in late 2011. I motorized it with a linear actuator and published the design in Digital Machinist, mid 2012. There was also a thread on this forum. Couple relays, a treadmill screw thread actuator, and Scott's hydraulic drawbar. Single button operation. Working in my shop for the past decade. Parts are still readily available, maybe 50 bucks and some machine time.
    PM me for a copy of the publication if you can't find it.
  1. Looking for actuated Vacuum Valves
    By Closetguy in forum DIY CNC Router Table Machines
    Last Post: 12-17-2017, 10:17 AM
  2. How do I electrically disconnect my Z axis limit switches
    By philbur in forum Tormach Personal CNC Mill
    Last Post: 01-12-2017, 08:31 AM
  3. DIY: Actuated chuck/collet for lathe
    By runcyclexcski in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2016, 12:12 AM
  4. Cam Actuated Drawbar
    By jstiltner in forum Benchtop Machines
    Last Post: 11-09-2009, 03:19 AM
  5. Electrically Insulated QCT Implementation
    By chris59 in forum Mach Lathe
    Last Post: 01-16-2006, 08:28 PM
